DigiWeigh 100 X 0.01 Gram Digital Jewelry Pocket Scale Logo
Mark Moshier Posted on May 23, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Numbers flashing on my digital scales - DigiWeigh 100 X 0.01 Gram Digital Jewelry Pocket Scale
Frank Wycoff
Level 2:
New Friend:
  • Expert 180 Answers
  • Posted on May 23, 2014
Frank Wycoff
Expert
Level 2:
New Friend:
Answers
180
Questions
Helped
44947
Points
491
Check to see if you need new batteries, or just remove batteries and reinstall to reset device.
If you need further help, reach me via phone at https://www.6ya.com/expert/frankie_091f536560a54e12
2answers
My digital gram scale does not work. the screen has some kind of word. Please help
Try recalibrating it by turning it on while holding the "tare" or "mode" button. It should show a raw data from the sensor then. Press the tare button again and it should calibrate the empty weight. Then it will show a specific weight you should put on, usually 100g. It should automatically finish calibration now. Hope this helps. The words before calibration on my scale was OUt2
Scale wont zero
Try to remove the battery and reinstall it after 5 secunds.
Be sure that the battery is ok.
TEC 21 SL calibration
I have a tech sl 21 on the start up the number displays just keep flashing and it wont stop help please
Digital readout not readable
Try a new one. If it works, the scale is broken.
3helpful
The numbers on the digital readout are partly
If the display is showing "partial digits" on the display, it means a scale is excessively shaken (sometimes during shipping) it's possible for the LCD to become partially separated from the PCB (Printed Circuit Board). On many models you can gently press on the LCD and it will reconnect. However on many scales it's difficult to reach the LCD (without removing the cover) and thus the scale will often have to be returned to the manufacturer for repair. Contact them at 1-800-326-6247 for the Conair appliance customer service center.
17helpful
2answers
When i turn on my digiweigh dw 100ax scales F--H appears on the screen how do i fix that and calibrate the scales when done
I thought the scale was just completely broken, I was able to fix by doing the following.
1. turn unit off
2. hold down the on/off/tare AND the MODE button.
3. The unit will come up with a bunch of numbers on the screen. Release the buttons
4. Press MODE once, you will see "100" flash on the screen. if you don't press the button a second time.
5. place 100g of tare weights on the scale.
6. Press MODE button again. After this my scale said PASSED and shut off.
7. remove tare weights and turn device on. It should now register properly.
In my case. the scale was misregistering the 50g weights as 75. I shut it off. I pulled up ever so slightly on the scale plate on the hinge side of the plate are repeated steps 1-7.
I have no idea why they don't have a 3 part calibration on these.
It is working like a charm now!
3helpful
Calibration is off
My Weight Watchers digital scales model#ww39 has gone haywire. I put new batteries in it to no avail. You tap it and the numbers come right up then changes to 000.0 as it should, when you step on the scales the numbers flash as they should but either they weight you about 100lbs to heavy or the numbers continue to blink and the LCD goes blank. Can they be fixed? Can I fix them myself at home? Do I need to shoot them? Just throw them out in the yard? Please I need help!!
9helpful
8answers
Conair scale ww36gd err reading
I have a WW36DG digital scale and most of the instructions are the same, so far as I can see. When you tap on the scale, 888.888 appears. It is just seting itself. If you step on the scale before it reads 00.0 it wil give you a Err signal. If you stepped on the scale after it read 00.0, and an Err signal appears, either your battery is very low or it is malfunctioning. it does have a 10 year warranty on it. For the person wanting to set the scale, here are the directions. Good luck.
Customizing Your
Weight Watchers® Body Fat Monitor
1. Tap center of scale platform with foot to activate digital display (display will
flash).
2. Wait for "0.0" to appear in display window.
3. You are now ready to input your personal data. Firmly press the SET button
located below the display.
Enter User Number
• P-01 will flash in display window
• Press UP or DOWN arrows to select your individual user
number (Ten user numbers available: P-01 through P-10)
• When selected user number appears in display, press SET
button to save user number
• The scale is now ready for you to enter your height
Set Height
• "Ht" (height) will flash in display window
• Press UP or DOWN arrows to scroll to your height measurement
• Press SET button to save height
• The scale is now ready for you to enter your age
Set Age
• "Age" will flash in display window
• Press UP or DOWN arrows to scroll to your age
• Press SET button to save age
• The scale is now ready for you to enter your gender
Set Gender
• The gender icons will flash in display window
• Press UP or DOWN arrows to select male or female icon
• Press SET button to save gender
• The scale is now ready for you to weigh yourself and to
determine percentage of body fat
Top DigiWeigh Measuring Tools & Sensors Experts
ADMIN Andrew
ADMIN Andrew
Steve Pack
Steve Pack
Are you a DigiWeigh Measuring Tool and Sensor Expert? Answer questions, earn points and help others
