Question about Epson RX620 All-In-One InkJet Photo Printer
I m using epson r230 printer plz. tel me best setting for dragon sheet printing for PVC ID Card
5 Related Answers
Anonymous
  • 700 Answers
SOURCE: my r230 photo printer epson stylus was sevice required unable to print and see your printer documents
Reset your printer. Look for printer resetter , its a utility third party program. Or in search of web browser just key in " epson reset software"
Posted on Apr 17, 2009
Anonymous
SOURCE: R230 Epson Printer
I cant print coz of my printer (R230 Epson Printer) blinking 2 red light. Printer dosnt ready. It say-Service required. how can I release this problem. Plz tell me.
Posted on Nov 19, 2009
Anonymous
SOURCE: service required for EPSON STYLUS R230
red light bhoth blinking
Posted on Dec 28, 2009
Anonymous
SOURCE: My Epson Stylus R230 has both red lights blinking
My Epson Stylus R230 has both red lights blinking alternately
please solove this problem
Posted on Jan 21, 2010
You need to reset your printer, because the ink counter is full,
all you need is to download the Epson Adjustment Program And reset the ink counter back to zero, so you can contineu using your printer
Sep 07, 2015 | Epson STYLUS R230 InkJet Photo Printer
Epson t60 wont print on pvc id card
Change your driver to R290 instead of T60. Select your T60 as printer (with an R290 driver) when printing. That would take the CD margin off the PVC card your printing on.
Aug 17, 2012 | Epson TM-T60 Printer
My new epson r230x printer is printing text and images blur
pls download the latest drivers software version of the printer that you use... then after that reinstall the old drivers software that you install previously.
Mar 02, 2010 | Epson STYLUS R230 InkJet Photo Printer
Two red lights are blinking simultaneously...I check if there is any paper jam but i don't see anything. anyone can help me would be much appreciated.
first have you checked any clogged papers? have you checked ink cartridges if yes continue doing the following
Before run adjustment program or software resetter Epson Stylus Photo R220 and R230, set date setting in your computer to 12 January 2006. Appearance of adjustment program Epson stylus photo R220 and R230 like adjustment program for Epson C45. Your Epson Stylus Photo R220 and R230 must be installed correctly in your computer before using the software otherwise so this software resetter will not be used.
Here how to use the software
  • Download and extract downloaded software and run it.
  • Click accept button.
  • Set model name, port selection and destination setting and equal to your printer.
  • Click Maintenance Tab.
  • Check mark waste ink pad counter.
  • And the clear the protection counter (reset counter to zero)
  • Then click Ok, Ok
  • done
download link:
http://www.mediafire.com/?9njmgwlxqgj
Nov 10, 2009 | Epson STYLUS R230 InkJet Photo Printer
My printer Epson Stylus PHOTO R230 does not print
The printer does not print only dragging a paper without printing.
3 option to solve
make sure your
1. heads are working
2. flex cable connecting the heads
3. main board
Most common that i found is to replaced the main board. or replace parts of other main board if you have some extra. hope it can help.
Jun 29, 2009 | Epson STYLUS R230 InkJet Photo Printer
R230 Epson Printer
Apr 17, 2009 | Epson STYLUS R230 InkJet Photo Printer
Paper jam
First, check the entire paper path for anything that would impede paper movement: a small piece of paper, staple, or even a broken piece of plastic from inside the printer itself. The rollers may have become either "slick" due to much use, or they can get covered with dust/paper dust. Cleaning them can help. I'm told rubbing alcohol tends to deteriorate them- perhaps using a diluted window cleaner. There are products sold for this- maybe do a google search on what to use.
Jul 16, 2007 | Epson Stylus Photo R220 InkJet Printer
Epson RX620 All-In-One InkJet Photo Printer Logo
44 people viewed this question
Top Epson Office Equipment & Supplies Experts
Ekse
Muntejaya Ginting
Muntejaya Ginting
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
