Question about Kia Vehicle Parts & Accessories
2005 kia sedona how to repair fuel pump - Kia Vehicle Parts & Accessories
Posted by Angelina Louisa... on
rjnworbnhoj
    Filmmaker:
    Uploaded 5 video answers.
    New Friend:
  • 142 Answers
2005 Kia sedona cranks but won't start
Check fuel pump fuse could be a fuel filter.
Jan 26, 2017 | 2005 Kia Sedona
Fuel pump/ relay/ wiring issues
They used the jumper wire to make sure that the fuel pump was running. For engine to run you need compression, air, fuel ,ignition.
Your problem lies with either fuel or ignition, and if you dealer cannot fix but continue to charge you, I would suggest you go elsewhere.
Aug 21, 2016 | 2005 Kia Sedona
How to remove the fuel pump on a 2005 kia sedona ex 3.5
buy a repair manual at any local autoparts store and it will lead you thru that process
Jun 15, 2015 | 2005 Kia Sedona EX
Oil sending unit location on 2005 sedona
The fuel level sending unit is located on the fuel pump assembly on a 2005 Nissa Altima.----------------------------------------------------------------------------------------
Odometer Correction Tool
Dec 20, 2012 | 2005 Kia Sedona
How to replace a timing belt on a 2005 kia sedona
Job is not too bad but engine and gearbox needs to be lifted to access removal of belt covers, are you handy with spanners also make sure fuel pump timing marks are set correctly
Apr 10, 2010 | 2005 Kia Sedona
How to change the fuel filter for 2004 kia sedona
I believe there is actually an access panel in front of the second row seat behind the drivers seat that you can access the top of the tank, fuel pump and possibly the fuel filter. Lift up the carpeting and check.
1. Remove the fuel tank cap to lower the fuel tank's internal pressure. 2. Locate access cover. 3. Remove the fuel pump & fuel filter assembly installation screws, then remove the fuel pump & fuel filter assembly from the fuel tank.
Jul 02, 2009 | 2005 Kia Sedona
Vehicle Parts & Accessories Logo
180 people viewed this question
Top Kia Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Kardoc
Marvin
Marvin
Are you a Kia Vehicle Part and Accessory Expert? Answer questions, earn points and help others
