Go to Start>> Control Panel>> Network Connections>> Right click your Local Area Connection and select Properties. Scroll the list for the entry titled: Internet Protocol (TCP/IP). Click the entry and select Properties. Under the General tab, tick the box titled: Use the following IP address. Enter the IP address and Subnet mask that you would like to use. eg - IP address = 192.198.0.1 & Subnet mask = 255.255.255.0.
SOURCE: printer unable to obtain IP address
Reset the TCP/IP information. To do so, Turn off the printer power. With the cartridge door open, hold down both cancel and continue buttons and power the printer on. Hold the buttons until the lights cycle. The TCP/IP information should be cleared. Wait a few minutes.The printer should pick up a new IP address from the network, or should set a default IP. Press the Continue button to print a new test page, and you should see the new address.
do you know how to network a 7420 fax ?
SOURCE: HP LASERJET 3055 Manual IP Address not saving
Try doing a cold reset first, then check that DHCP is manual not Auto. then try to input IP address again. If the Network card is seperate then you may only have to replace the Nic
SOURCE: HP LaserJet 3055 unable to save IP setting
i can solved this problem please give me one chance
SOURCE: IP address to connect HP2035N on the network
Here's a good tutorial that may help...
See this MS article, though you don't mention whether xp or vista....(see here for vista)
See here. and here for HP info.
For more info on TCP/IP see here and here.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Testimonial: "Many thanks for your help. You fixed my problem!"
The assigned IP address and subnet mask displays.
IP address and netmask: 10.1.0.1 255.255.252.0 on VLAN 1,
and address mode: User specified.
Console#
Before you can assign a static IP address to
the switch, you must obtain the following information from your network
administrator:
Console(config)# interface vlan 1
Console(config-if)# ip address 192.168.1.5 255.255.255.0
Console(config)# ip default-gateway 192.168.1.254
Console(config)#
To configure the switch for DHCP or BOOTP:
First find
out the IP address , Subnet mask,and Gateway addresses of your ISP ( Internet
Service Provider ). According to above addresses, you have to complete the network
settings of your printer by mentioning the different IP address .
To find out the above mentioned
addresses, first open the control panel -> network connections -> local area
connction -> properties -> Internet Protocol Version 4(TCP/IPV4) OR
Internet Protocol Version 6 (TCP/IPV6)according to your ISP -> Properties
By the systematic selection as
mentioned above you will get the IP address, subnet mask and Gateway addresses.
Suppose your IP address is 192.168.0.10 , the
gateway may be 192.168.0.1 Or any number. And the subnet mask may be
XYY.XYY.XYY.0.
According
to your ISP addresses you have to complete the network settings of your
printer. First press the additional functions -> system settings ->
network settings -> TCP/IP settings -> fill up the addresses as follows.
IP address : 192.168.0.16 OR any number .
subnet mask : XYY.XYY.XYY.0.
Gateway : 192.168.0.1
Hurray ! the problem about your network connection with the printer to your computer will be automatically solved.
