Toshiba estudio 255 Copier Logo
A
Anonymous Posted on May 22, 2014
Shows misfeed in document feeder and does not copy
1 Related Answer
goalie39
Ed
  • 479 Answers
  • Posted on May 12, 2009
SOURCE: copies run through feeder distorted
Document feeder Paper feed rollers should be cleaned with alcohol, blow out the document feed area with compressed air (computer duster), check feeder for bits of paper, post it notes, and signature flags. Clean glass, check for sticky areas on the glass.
Hope this is of some help.
Ed
1helpful
Xerox WorkCentre 7120 error code
Chain Description 001 Cover and Door Interlocks 002 Touch Screen / Control Panel 003, 041, 045, 123 Machine Communications 004 Drives 005 Duplex Automatic Document Feeder (DADF) 061, 062 Scanner, DADF and ROS 007 Paper Supply 008 Paper Feed 009, 089 Xerographics 010, 011 Fuser, Copy Exit 012, 013, 047, 112 Finisher 016, 124, 127 Configuration, Software, Memory, Hard Drives, Color Server, DFE 018 Network Communications 020 Fax, Software 021, 121 Foreign Interface 022 Job Timers 024, 026, 027, 033 Job Parameters 034, 035, 036, 133, 134 Fax Communication 042 Motor, Fan, Sensor 071 Tray 1 Misfeed 072 Tray 2 Misfeed 073 Tray 3 Misfeed 074 Tray 4 Misfeed 075 Tray 5 Misfeed (Bypass Tray) 077 Paper Path Jam 078 High Capacity Feeder 083, 084 Fax Jobs 091 Drum Cartridge 092, 093 ATC, ADC, Toner 094 IBT, BTR 102 Job Queue 103, 116 Software
2helpful
6answers
MISFEED INDICATOR BLINKING
DEAR SIR WHERE YOU REMOVE THE PAPER IN THE MACHINE THAT SECTION THERE IS PAPER PATH SENSOR ,THAT SENSOR POSITION IS ABNORMAL PLEASE CHECK THE SENSOR OF THAT SECTION WHERE YOU REMOVED THE PAPER
Hope this may help;
Regards,
VOTIT
I have a Epson cx11 and get a black vertical line down the middle of scans and copies
Check your flat bed and Document feeder scanning glass need to be clean, if any dot or dust in scanning glass of document feeder it will appear a line, check this points first
1- Check printouts from computer or FAX if it is clean problem in scanning section
2- Check using Copying a blank paper using only Flatbed if it prints without any line its problem from document feeder Scanning glass
So solution is clean the Document feeder scanning glass using wet cloth, note careful about wet cloth switch off the machine and clean it
Sharp AR-M237 a misfeed has occurred, top feeder. there is no paper have did as the information states and still will not clear.
Is the jam indicated inside the copier or on the document feeder that scans the paper across the glass ?
Blank line down left side of outgoing fax or feeder copy
The most common cause of blank (void) lines on a scanned document is from whiteout on the glass where the page is scanned when using the document feeder.
If there is a clear mylar sheet on the bottom of the document feeder, the whiteout may be there instead.
If there was dirt or a dark smudge on the glass (or mylar), it would show up as a black line, but whiteout is white, and shows up as a void (blank) line.
Misfeed detected but no paper jam
Di 251 is legacy Minolta machine, Minolta is now Konica Minolta
for the image unit try this site
Precision Roller Printer Toner Cartridges Parts and Supplies Office...
as for the adf replace!!! the rollers all three try the same site above
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Paper Feeder Jams
Use this link and when you call ask for Britt. I do NOT work there but I have used them for a long time and they are greart.
Here is the URL ..
https://www.partsdrop.com/store/
Black lines showing up on documents fed thru the document feeder.
Clean the small glass under the doc feeder very very well...
Faxing and copying
clean the big rubber roller on the document feeder with windex applied to a micrfiber cloth and then try to fax or copy two sheets
Top Toshiba Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
Norman Weimar
Norman Weimar
Grand Canyon Tech
Grand Canyon Tech
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
