Bosch 18 in. SRS45E02 / SRS45E08 Exxcel Slim-Line Free-standing Dishwasher Logo
Question about Bosch 18 in. SRS45E02 / SRS45E08 Exxcel Slim-Line Free-standing Dishwasher
Tricity bendix model dh102
Isnt filling with water
Posted by Lisa High on
Jacob Schraeter
    New Friend:
It's either an intake valve just where the hose meets the machine or a bad pump.
Posted on May 23, 2014
Dh102 not letting water in to start cycle
check the valve and the outlet to fix properly. or check with the service technician. thanks
Model DH102 Leaking water from under Dishwasher'
Here is a tip that I wrote about dishwashers and them leaking.
Leaking Dishwasher
heatman101
qw36q
DH102 will not drain of water
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems - Water will not drain out
heatman101
1helpful
Bendix dishwasher not pumping out water
hello,
what this indicate is that there are been a blockage on the water drainage,
what you are to do to fix up this problem is to remove the material in the washer if any then bale out the water with small bole or bucket if any then trace the water drainage down to the out flow you will fine some dirt or cloth that have cost the blockage remove it then the problem is solve .
With this your washer will be able to pump out water again as expected.
thank you
Tricity bendix dh101 wont empty trying to but only a trickle was working ok no kinks in extract pipe
Check the drain hose and the drain lines, if you find no obstructions, then you have a defective drain pump.
If you find no problem with the drain lines, you may need to replace the pump.
If you enter model number here , you can find parts and diagrams.
Check pressure from power supply, check if the inlet valve is faulty or obsstructed.
Water will not fill
Check also the door switch, if that is stuck or defective, the machine won't start the cycle.
8helpful
2answers
Tricity Bendix DH101 dishwasher
my tricity bendix dh101 will not fill up with water what could be the problem
My Tricity Bendix won't work
Check out the water inlet solenoid valve if this is clicking then it is probably the water level pressure switch which appears to be controling the flow of water mechanicaly dependent on whether the water is high enough in the machine and therefore giving enough pressure to close the switch .This may be stuck closed.
Top Bosch Dishwashers Experts
mark warfield
mark warfield
David Shaub
Marvin
Marvin
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
