Question about Linksys SPA-2102 NA Analog VoIP Adapter (2) FXS, (2) RJ45 (SPA2102-NA)
I want to change password
SOURCE: lINKSYS wrt 300n
Ok, I recieved one of these routers a while back to fix and I think that some D-Link's access has been disabled. To reset the router back to default settings, on the back of the D-Link, hold in the small reset button in the hole for about 4 seconds and it should restart. Then, all settings on the thing will be reset back to the defaults set by D-Link!
Posted on Jan 17, 2008
SOURCE: need my i phone to
On the bottom of your DSL unit on the product info sticker, there should be a "WEP" alpha-numeric code. Thats the code that I use for mine.
Posted on Jan 03, 2009
SOURCE: I need to change my password to accesss wi-fi
username and password for accessing router is on a label on the router
usually admin admin
make sure the computer is connected via an ethernet lead to your router. Then open internet explorer and enter 192.168.1.1 into the address bar, then enter the username and password then choose advanced then wireless ,make sure its enables then choose security and write your key in
Posted on Dec 29, 2009
SOURCE: I set up a home wi-fi network and have changed lap
There are several things you can do, both of which require you to plug your laptop into the router directly via Ethernet cable. These instructions are for a majority of Linksys Wireless Routers, but may work on others.
If you cannot connect and you are sure you have written down the password and entered it correctly, do a reboot of the modem and router in this order.
Good Luck!
Chris
Posted on Sep 28, 2010
