Question about Yamaha HTR-5830 Receiver
Can the htr 5830 be used without a remote
I have no remote for the htr 5830 can I still use it or can i get a remote for it.
4 Suggested Answers
6ya staff
SOURCE:
Anonymous
SOURCE: yamaha htr-5830
I own this receiver, and 18db is damn loud. Granted - your room might be significantly larger than mine with your speakers spread much further apart, or your speakers might be much less efficient than mine (this means that they want more power than the receiver can dish out - I have whatever speakers came with the "YAMAHA Home Theater in a Box" [the model that came with the HTR-5830]), but I'm pretty sure that the receiver doesn't get any louder (or at least not much). My suggestion is to turn down the volume to about -20db and work up from there after the movie has started. It might be easier to test the volume using music. The negative sign is deceiving - I rarely bring mine up to 0db. Also check the resistance - there's a red switch on the back of the receiver that switches between 6 and 8 ohms - make sure that it matches your speakers' resistance. If turning down the volume doesn't work, then post the problem again. Hope This Helps.
Posted on Nov 07, 2006
Anonymous
  • 15 Answers
SOURCE: Setup
dvd and dish tv optical inputs from both dvd and tv if tv has opticl out or give optical out from hd receiver. or rc pins from hd or tv to dtv/cable input of yamaha
Posted on Feb 02, 2009
Anonymous
  • 7 Answers
SOURCE: Yamaha HTR 5830 sound and no pic?
make sure that the yellow video jack is on the tv out on the surround unit and is plugged into the video jack on the tv. You may have to change the input on your tv to Video1 or Video2 to get the pic to come in
Posted on Jun 07, 2009
What gauge speaker wire does a yamaha HTR-5830 use?
I dont think you can get much larger than 12 gauge wire into the speaker terminals
Feb 28, 2013 | Yamaha HTR-5830 Receiver
Can I hook up wireless speakers to Yamaha HTR-5830?
there are wireless kits available, and most all yamahas have pre-amp outputs for all the channels
Find Blu-ray player compatible with Yamaha htr-5830
Hello James,I have the exact same issue, did you have any luck?
Dec 28, 2012 | Yamaha HTR-5830 Receiver
Cant get front left and right speakers to produce sound....when i try to use the receiver remote to turn up the decibals on the front speakers it wont go past "0"...it will go into the negatives...
1. Speaker B instead of A selected??? Page 53.
2. As far as the Fronts limiting to 0 dB, they are the reference for all others. Perhaps the engineers thought it made no sense for the stake in the ground to have a moving reference level. See step 3 on Page 50.
http://www.retrevo.com/support/Yamaha-HTR-5830-Receivers-manual/id/394ci070/t/2/
Jan 22, 2011 | Yamaha HTR-5830 Receiver
Yamaha HTR-5830 does not work with Sony PS3 optical cable connection. There is no sound at all. Do I need an HDMI cable. Right now I only have component cables which work fine with the red and white...
Make sure you have the "audio input mode" on "Auto" it's a small button on the front of the Yamaha. Then go into the PS3's Audio setup and make sure it's set to Digital. Hope this helps
Jun 04, 2010 | Yamaha HTR-5830 Receiver
I am trying to hook up my Yamaha Universal Dock YDS-11 for my iPod touch into my Yamaha HTR 5830 Amp but there is not where to plug it into. Do I need another type of cables to do this.
Hi, I'm afraid that your receiver doesn't support YDS-11. You can check it at yamaha site. This dock uses special cable and special connector on the receiver (which yours doesn't have).
So the only way to connect your iPod to receiver is via analog audio output (jack connector on the iPod).
Jan 29, 2010 | Yamaha HTR-5830 Receiver
Yamaha HTR 5830 sound and no pic? I get sound in both DVD and TV?CBL modes but no picture.
Jun 07, 2009 | Yamaha HTR-5830 Receiver
Sound problems
If the remote can work other functions of the receiver then check the owners manual, it may tell you how to reset the receiver.
Jan 03, 2009 | Yamaha HTR-5830 Receiver
Connecting an audio/video transmitter to Yamaha HTR 5830 Amp
If you want to get sound out to speakers use the KEFF WIRELESS SYSTEM as this will not break up or cut out.
Hope this helps.
CABLE GUY.
Dec 29, 2008 | Audio Players & Recorders
HTR-5830
The liquid has shorted out probably every electronic component in the unit. It is fried. You need a new one.
Mar 27, 2008 | Yamaha HTR-5830 Receiver
Yamaha HTR-5830 Receiver Logo
65 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Colin Stickland
Colin Stickland
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
