Question about Sanyo Katana SCP-6600 Cellular Phone
My phone won't vibrate (Sanyo Katana)
I have a Sanyo Katana- Bought it in April. Everything is fine with it, except that it has now decided not to vibrate when I get a call or text message. It started with a gradual weakening of the vibrate function, then one day it just stopped altogether. It didn't vibrate for a few months, and then one day, I had it on the coffee table and it practically "walked" off the table. Now, it will vibrate here and there, some days functioning very well, and others, barely, if at all. Has anyone ever seen anything like this?
Posted by Zulmorah on
  • Anonymous Nov 14, 2007
    I had a similar issue, which unfortunately, today capped off with the
    screens failing to work any longer. The main LCD glows a bright white
    with a single pixel wide yellow line about 4 cm to the right of center.
    The faceplate LCD just glows a very dull gay. I hope that your problem
    will not end up like mine did, good luck friend.
  • elmo_035 Nov 24, 2008
    i have the same problem. i tried taking the battery out and it fixed my screen.  the screen looked like it was set on the "always off" backlight setting and now it's good (knock on wood) but it still won't vibrate. can't wait to get a new phone...
Anonymous
I keep having that trouble, too: when I connect to the power supply, it disables the vibrate feature (probably to avoid electrical problems), but sometimes it doesn't come back when I disconnect it from the power supply. In those cases, I reconnect it, disconnect it again, and usually it works.
Posted on Sep 22, 2009
Anonymous
My Katana randomly decides to not vibrate too. I either take out the battery, or i tap/hit the back of the battery (while still in the phone) to make to vibrate again. TLC my ****, give it a good "love tap"
Posted on May 23, 2009
Anonymous
Not gonna lie, i just lightly tapped the side of my phone on my desk when i had this issue. it started vibrating again and i've had no problems since. (this was about 5 months ago)
Posted on May 24, 2008
Anonymous
I agree with kboy667!
All I did was pop out the battery and put it back in and not's it's working fine! :)
Posted on Mar 20, 2008
Anonymous
I have the same prob just today it stopped vibrating all together. But my phone came all messed up because it didnt have some prgramming codes in it so the sprint pace on the phone had me practactly hack the matrix of my phone. It was pretty interesting, but anyway yeah i have the same prob thinking of upgrading.
Posted on Jan 13, 2008
  • Anonymous Jan 13, 2008
    okay well while i was wating on the phone with sprint i just decided to remove the battery and put it back in. Upon start up my vibration was working again, try it. :)
How do I set phone to vibrate
To turn on the vibration of the phone,
First you go to the settings,
Select the profile,
Select personalize,
Go to the ring option,
Select the Vibrate and ring option.
Then you activate the profile.
Take care
Jun 19, 2010 | Sanyo Katana LX Cell Phone
Tip
Katana Eclipse X Manual Download
Download Sanyo Katana Eclipse X Cell Phone Manual
Have you misplaced your Sanyo Katana Eclipse X Cell Phone Owners Manual?
Would you like a digital, searchable, pdf version of the Sanyo Katana Eclipse X Cell Phone Users Guide?
Follow this link (& click FREE) to download a pdf version of the Sanyo Katana Eclipse X Cell Phone documentation.
I hope that helps.
on May 06, 2010 | Cell Phones
Tip
I hope that helps.
__________________________________________
on May 06, 2010 | Sanyo Katana Eclipse X Cell Phone
Not charging
Your battery needs to be replaced. make sure you fully charge the new one and completly drain it before charging it again. don't interupt the charging till its full that will shorten the life of your battery consiterably!
Jun 09, 2009 | Sanyo Katana Eclipse X Cell Phone
Bought ph on trademe telecom nz prepay works fine i just wasnt given security lock code details is there a master lock code sanyo scp 6600?
hi
menu > settings > security > change lock code > apply master code in place of lock code and press ok > enter new code what you want
Jun 01, 2009 | Sanyo Katana SCP-6600 Cellular Phone
Cell phone quit vibrating
No its not normal and yes it can be fixed thou if you dont have insurance and its not a known defect (likely) you are probably better off taking it to a Sprint store and asking them to upgrade or buy a refurb. on the net.
Mar 15, 2008 | Sanyo Katana SCP-6600 Cellular Phone
Katana II likely water damage... Help!
Take the battery off, unfold the phone, set it in a warm, dry place and pray like heck. plugging it in may help it stay warm but leave it off.
If its minor water exposure it'll likely be fine in 2-3 days.
Mar 02, 2008 | Sanyo Katana SCP-6600 Cellular Phone
Buttons won't work
Did you get it wet....that usually happens when the phone has been wet.
Sep 15, 2007 | Sanyo Katana SCP-6600 Cellular Phone
Katana- Submerged in water for less than 2 minutes
Dang, that is not good the keypad is waterdamaged for good. Take it into a store and have them run a diagnostic on the phone itself. As far as the incoming calls you should still be able to receive those... that is weird actually I would call in for that. Hope that helps :)
Aug 28, 2007 | Sanyo Katana SCP-6600 Cellular Phone
Sanyo Katana SCP-6600 Cellular Phone Logo
811 people viewed this question
Top Sanyo Cell Phones Experts
Ekse
Marvin
Marvin
Colin Stickland
Colin Stickland
Are you a Sanyo Cell Phone Expert? Answer questions, earn points and help others
