Acer Aspire 1310 Power Socket
How do I take apart above laplop to replace or repair the power socket. I cannot find a disassembly guide on line.
Any help would be appreciated.
Posted by StewWatson on
Anonymous
  • 117 Answers
Acer servie center that is best
Posted on Nov 05, 2007
My acer aspire notebook 7736Z-4412 won't turn on. I have tried taking out the battery and using the adapter but it still won't turn on?
yes boss pl remove ur battery n start only ac supply if ur laptop on or not if run ur battery defective or not run at ac ur laptop ac supply ac to dc converter circuit problem pl send my address solved n send u
May 26, 2014 | Acer Aspire One PC Notebook
Power cord when connected to laptop does not power up. There is no teltale sign of damage to power cord. There is a slight wiggle of the male prong when inserted in the 12v circle socket. Could it be the...
The DC jack, where you plug the power adapter cable, might be loose or defective, & needs to be either re-soldered or replaced.
In order to do this, the laptop needs to be disassembled & the motherboard taken out. Also, the motherboard needs to be checked for defective/burned out components in the area near the DC jack. Any defective/burned out components found should be replaced, or you might need to replace the laptop's motherboard altogether.
Sep 16, 2010 | Acer Aspire One Netbook 8.9" Notebook
How do I disassemble my acer 5135 to get to the power jack or where will i find a step by step guide
Before you rush and do some irreversible damage - check if it is still under warranty, I would suggest first checking on this site if you have warranty on it:
http://secure3.tx.acer.com/FindSystem/FindSystem.aspx?title=Information
If you do not have any warranty left, do not bother sending it for repair! minimum charge is about $100.00 and you can have newer and better one for about $400.00
Replacement of broken power socket inside of your laptop is not exactly for faintarted... in this laptop it is soldered to the motherboard and acer on this model is notorious for doing very sloppy job with it.
As I do not have manual for that particular model (Acer did not bother to provide workshop manuals for that one...), I can provide only general instruction.
1. Remove power cord and battery, disconnect any auxilliaries if connected. This step is must before you even think about repair.
2. Prepare 000 and 00 philips screwdriver (middle and smal), pointed soldering iron, solder wick and solder.
These sites will provide you with some idea howto:
http://www.insidemylaptop.com/taking-apart-acer-aspire-5100-laptop/
http://www.laptoprepair101.com/laptop/2007/12/06/dc-power-jack-repair-guide/
http://defectivekit.com/2007/02/15/guide-to-fixing-a-laptop-power-jack-a-do-it-yourselfer/
Another word of advice - do not rush! If you never done that before, ask some friend which done bit of soldering. When you put your laptop apart, this repair takes me between 20min to 35min, be prepared for 2hrs.
Prepare clean table without anything on it except butrchers paper, your tools, static strap (many laptops are killed by static electricity!), your laptop.
Put your screws and part in order in which you removed them, make picture on stages before you disconnect any cable, most ribbon cables on laptop are slide in type.
Your parts will go back in reverse order as you take them out.
Aug 10, 2010 | Acer Aspire 5315 Notebook
I have aan Acer Aspire 5315 which is 2 and a half years old. The battery died so I plugged in the cable in the usual way and nothing happened no lights came on. I assumed the powercable needed replacing...
The power ports are generally the problem. If you wiggle the wire and get contact that is almost sure that is it. The Internet has folks that will fix this problem.
http://www.laptoprepair101.com/laptop/2007/12/06/dc-power-jack-repair-guide/ shows how to repair it yourself.
Aug 03, 2010 | Acer Aspire 5315 Notebook
Repairing power socket for acer aspire 3690
brows this site n see how to repair power jack,
Feb 07, 2010 | Acer Aspire 3690-2196 Notebook
My power won't turn on. The battery and the cable
Check the power adapter with a multi-meter, the voltage of the power plug that plugs into the power socket on the laptop should be slight higher than the voltage that is printed on the label on the adapter.
If it is faulty, there are replacement power supplies available on the Internet or at your friendly computer shop.
If the adapter is OK then the power socket on the laptop is faulty or this socket has a dry solder joint connection on the motherboard.
You can test this by wriggling the power plug when it is connected to the laptop, if the charge LED flickers and if you hold this plug in a certain position the charge LED stays on without flickering, then the power socket is faulty.
This can be repaired, but requires the laptop to be completely
disassembled. I suggest you get a quote first.
Oct 07, 2009 | Acer Aspire 3680 Laptop
No power wont charge battery power cord works though
Sep 28, 2009 | Acer Aspire 6920 Notebook PC
I have acer 4730z, no power on
Sep 28, 2009 | Acer Aspire 4730-4947 Notebook
MY acer aspire 3680 not powering on. The light on the power cord is on but the light at the front of the laptop is not showing. I took out the battery and replaced it no differennce. I held down the power...
When you wriggle the plug in the power socket on the laptop and the charge LED flashes and in the right position it charges, this indicates that the power socket is faulty or there is a dry solder joint on the motherboard where this power socket is attached.
To get at the power socket will require dismantling the laptop completely.
If you are confident, can dismantle, reassemble a laptop and use a temperture controlled solder iron then try and fix it. If not a computer repair shop can do the repair, I suggest you get a quote first.
Aug 26, 2009 | Acer Aspire 3680 Laptop
The socket is loose so the ac adapter doesnt make connection so tryint to get base off but its not poppin off and i've came across all the screws.
It is not available in the market so you need to contact any acer service cernter for replacing the power adapter socket..
May 23, 2009 | Acer Aspire 3000 Notebook
Computers & Internet Logo
439 people viewed this question
Ekse
Marvin
Marvin
