Fisher and Paykel DishDrawer DS605FDSM Stainless Steel 23 in Builtin Dishwasher Logo
Question about Fisher and Paykel DishDrawer DS605FDSM Stainless Steel 23 in Builtin Dishwasher
Fisher paykel troubleshooting
Top drawer has no power and is locked
5 Related Answers
Anonymous
  • 125 Answers
SOURCE: fisher and paykel leak
most likely the actuators are bad. with the unit off push and hold the lock and start buttons, lock first then start, after about 6 seconds the display will flash 188. press the power button, ho will be displayed. push the start button until Ld is displayed. open the drawer in question and push the lock button and watch the lid both sides should go down evenly, push the lock key to move it up and down as needed. push the power button to exit diagnostics. if you notice that the lid doesn't go down evenly or if one side stays up replace the actuators, they come as a pair. call a dealer/servicer to order actuators. make sure to specify top or bottom as there is a difference. hope this helps
Posted on Mar 03, 2009
Anonymous
  • 205 Answers
SOURCE: Fisher & Paykel DD601 top drawer won't start.
Most likely the micro-switch that tells the controller that the drawer is closed is broken. Its a tiny little black switch at the back of the left drawer slide, it had a metal actuator that is prone to breaking.
Posted on Jul 21, 2009
Anonymous
  • 784 Answers
SOURCE: Fisher Paykel dishwasher drawer won't stop.
Let's go to diagnostic test mode to see if you can retrieve the the actuator hence the tube out.
1- Press Lock button and start/pause key until the display showing up.
2- Press Power to show HO.
3- Press start button to advance the display until you see P2 for draining, if you pass, keep doing it to get it back in a loop.
4- When at P2, press lock to turn on, press a again to turn off.
5- Listen to the sound of the pump. If you hear nothing that means the pump is dead or stuck.
6- The Motor has 2 directions: one for, Rinse and one for Drain. When you done with the diagnostic, press the power button to get out of the mode.
7- If this is the case, unplug the power then remove the rack, the bottom stanless steel plate with holes then take out the rotor to clean up. It is a good design the stator is outside of the tube, so you don't have to worry too much about the complication.
8- Make a note of all the positions so you can put them back the same as they were. Good luck
Posted on Sep 09, 2009
Anonymous
SOURCE: Fisher and Paykel DD603 top drawer jammed and will
Hey, I had this problem before!!!! Just unplug the unit off and wait about 10sec and plug it back on.....that usually does the trick.
Posted on Nov 26, 2009
Anonymous
  • 784 Answers
SOURCE: I have a Fisher Paykel dishwasher with water in top drawer
You need a Air gap kit designed by Fisher and Paykel to address this problem. It is pricey but it is worthy. I used this and very happy with it since no back flow problem from one while other running. Here is a link to order it.http://www.fisherpaykelparts.net/product/WT50/WT50-Dual-Air-Gap-Kit/
Posted on Dec 29, 2009
Fisher and Paykel Dishwasher, the top drawer power light turns on and off!
Question edited for clarity and the addition of 'Dishwasher'.
Check out the video in the link
https://www.google.com/search?q=Fisher+and+Paykel+Dishwasher%2C+the+top+drawer+power+light+turns+on+and+off
Please always include 'make model (what it is)' in all questions. Thanks.
Error E45 on fisher & paykle dishwasher
Reset Procedures for the Fisher & Paykel Dishwasher
  1. Press and hold the button decorated with the key and lock image for five seconds.
  2. Press the power button to turn off power to the Fisher & Paykel dishwasher.
  3. Wait a few minutes and then press the power button to restore power.
  4. Turn off and unplug the dishwasher if the issue remains.
1helpful
Can i disable the bottom drawer on a Fisher and Paykel dishwasher and only use the top drawer
You cannot disable, as in turn off, permanently, but you can turn off with the power (left most) button and then lock the control (right most button) by pressing and holding it for approx. 3-5 seconds. The lock symbol will illuminate. Now the lower drawer cannot be operated - unless the lock is released. You cannot disconnect the lower drawer as this will cause a U4 or similar error and both drawers will shut off.
Top drawer can not be open
If this is a double drawer dishwasher and bottom drawing is functional but top drawer won't open means the controller on top drawer is faulty or power circuit is locked. If turning the mains power off and back on makes no difference then controller could be the problem. One way to test is to take the controller from bottom drawer and replace that in the top drawer. This requires a lot of patience and experience with electronic stuff. If you are not brave enough to test then call the technician. The controller is about $200 to buy. Make sure the mains power socket is taken out before working on the dishwasher internals.
FISHER PAYKEL DISHWASHER DD603 Parts
F1 error on Fisher and Paykel Dish Drawer
Sorry did not see your problem report earlier. If you have checked the sensor under the bottom drawer and it is dry, then F1 is caused by top drawer power filter fault. This means the bottom drawer controller is giving the F1 error but the top drawer controller has no power. Can you confirm this.
Fisher and Paykel dishdrawer, lid not retracting, no power.
By no power you may be implying there is no display etc and the swithces are not working. Most likely the controller of the top drawer has had it. The controller is mounted on the front of the drawer behind the door panel. Hope things are better than that.
Top drawer has no electrical power
I f lock is activated during wash the draw will appear dead when wash cycle finishes ,check for lock symbol in lcd display if it is visible press lock button for about 5 seconds until you hear beep release button and try POWER button
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
Marvin
Marvin
Paul Bade
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
