Question about Logitech Revue with Google TV Refurbished
How do i get a Regents HT-391 surround sound system to play sound from my Logitech Revue with Google TV?
The Regents HT-391 system plays sound from the TV,Satellite or Cable. However I can not get the Regents HT-391 system to play sound produced when operating the Logitech Revue with Google TV. Nothing when connected to the web will play sound from my Regents system.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 40 Answers
More than likely the regent system is needing and alternate audio source, via- analog, digital coax, optical ect... HAs it always been this way, or use to work?
Posted on Dec 01, 2014
2 Suggested Answers
Anonymous
  • 103 Answers
SOURCE: my surround system is playing on the dvd but there is no sound
check your cable settings if its inserted in the correct plug-in....also check if its not muted....also try to play other disc if there is a sound coming from the speakers
Posted on Nov 13, 2009
Robert
  • 45 Answers
SOURCE: logitech speaker system z323
Unfortunately, manufacturers have decided we no longer need analog audio output jacks. I will never understand why. They do however still include an optical audio output connection. Go on Ebay and look up optical to analog audio output adaptor. Should run you about $20. You may also findnone at Best Buy but will set you back $60. Be sure to set the TV settings to PCM audio output. Otherwise you'll get no sound.
Posted on Dec 29, 2013
Samsung HTX715 will not play 5.1 surround sound from TV signal only works from DVDs any ideas, back speakers do not produce any sound
In any native or automatic sound mode the HT will only produce mutichannel sound from multichannel sources delivering a digital bitstream. Is that the case with the TV? The best source for TV related audio is from the source, usually the cable box. Read the manual.
Sep 18, 2011 | Samsung HT-X715T Theater System
My Phillips HTS3520 plays DVDs fine and the sound is excellent. However, it is not playing the TV channels thorugh the theatre system.
Without more data, I can only make some general suggestions.
First: Check your cables. If you are using a converter box, there must be a set of audio and video cables going from the cable box to the Home Theatre unit. These will be a yellow/white/red set of cables. Second: If these cables are plugged into "AUX1" or "AUX2" make sure this is what reads on the front of the HT unit. You already have cables going from the HT to the TV because your DVD works.
Although this sounds obvious (please forgive me-I am not underestimating you) IF your TV receiver is 6 years old or more, and you are NOT using cable or satellite, there will be nothing for your set to pick up since the conversion from analog to digital.
Jun 05, 2011 | Philips Audio Players & Recorders
Can not get my Samsung TV to recognize the ht system. I am able to get the sound out of the ht system and the video on the tv when i play dvds but the sound will not transfer from the tv to the ht system...
The way mine is hooked up is like this: Ps3, DirecTV box all plugged to my samsung TV and then only thing I have plugged into the Ht box is the hdmi out to TV and an Optical Cable from Tv to HT box. All audio is going to Tv then to HT box and plays all through hometheater box when it is on. Try the optical cable
Sep 22, 2010 | Samsung HTC650 Theater System
Samsung LED UE46B7020 tv wont play sound through my HT-C5500
i know this is going to sound stupid but i couldn't get mine to work either after following every instruction to the T. I then rechecked my optical digital connections again and found that I neglected to remove one on the rubber protective endings. I took it off and plugged the end back into my TV and BINGO! THEATER SOUND from my tv!
The Ticket
May 09, 2010 | Samsung HTC550 Theater System
I have an LG all in one home theatre system, LCD TV and Direct TV satellite box. It is all hooked up and working fine except I only hear the sound through the speakers when playing a dvd or radio. The...
OK. For all you regular Joe's like me here's the fix--plain and simple! I have Dish Networks HD receiver, an LG Home Theater System (LHB953) and an LG HD Television - although I suspect this applies for most LG TV-to-LG Audio Systems used in combination with a HD TV). My problem lied within the LG to LG setting known as SIMPLINK which tries to "auto-configure" everything between LG to LG devices.
Do this to make your HD TV (using Dish/DirecTV) play it's HD video display from the satellite provider but play the audio over the LG surround sound speakers:
1. Plug a HDMI cable from your satelite receiver's set-top-box to your HD TV. This will carry your HD "video" ONLY. Click "Input" on the TV remote until the HD video signal shows your desired TV channel from your satellite provider.
2. Plug an HD Optical cable (the one with the red laser) from your LG HTS (Home Theater System) to your satellite box. This will carry your HD "audio" ONLY.
3. This is the magic everyone seems to be overlooking. On the LG TV remote, go into the menu options and disable SIMPLINK by setting SIMPLINK=OFF. This feature allows the video and audio signals to be split over 2 different ports: HD video goes over the HDMI cable and the audio to go over the HD Optical cable.
Hope this helps!
Scott C.
Feb 01, 2010 | LG LHB953 Theater System
REGENT MODEL HT391 SURROUND SYSTEM
i need to know how to hook up my home theater to my TV and Dvd.
Oct 04, 2008 | Durabrand HT-3915 System
How do I get my tv to play through the surround sound
If you have direct cable into the television, you will need to use an audio output if available on the back of your set into your HT system.
If you are using cable w/ a cable box you have two options. You can still connect everything directly into the TV then reroute the audio to the HT system... or, you could hook only video to the TV and audio from the cable box to the HT system. Really up to you.
Mar 04, 2008 | Panasonic SC-HT680 System
I have a Samsung HT-X50 Surround Sound, a LG 50" Plasma 50PC5D TV, and DISH Network Satellite.
How can I get surround sound to work on my tv. When I pull up my menu and go to audio the SRS Trusurround XT is not in bold so I cant figure how to connect it so I can have the surround sound coming from the system and not from the tv. Please help.
Dec 24, 2007 | Samsung HT-X50 System
Logitech Revue with Google TV Refurbished Logo
270 people viewed this question
Top Logitech Audio Players & Recorders Experts
Ekse
Michial Gueffroy
Marvin
Marvin
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
