Question about Kodak EasyShare C360 Digital Camera
How to format sd card c360 - Kodak EasyShare C360 Digital Camera
2 Related Answers
Ty Price
  • 11967 Answers
SOURCE: i have a kodak easyshare c360 and it wont format
Is the slide switch on the side of the card in the unlocked position?
Posted on Dec 10, 2009
Anonymous
  • 297 Answers
SOURCE: I have a Easy Share Kodak C360 digital camera and
hello marybell769,
I dont know if a digital camera has the ability to format,but if you try to format it in computer,be sure to save all files within it..
Posted on Dec 28, 2010
Memory card error
Look at your memory card. SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Jan 11, 2014 | Kodak EasyShare C360 Digital Camera
Camera cannot read card
This requires a SD memory card. I would stay with 512 mb or smaller.
Nov 10, 2012 | Kodak EasyShare C360 Digital Camera
Is the memory card of 8 gb is supported by the kodak easy share c360 camera?
No. You cannot use a 8GB SDHC card in the C360. The C360 supports MMC and SD cards up to 2GB in size.
May 15, 2011 | Kodak EasyShare C360 Digital Camera
Hi, i have had my kodak easyshare C360 camera for a few years now and just purchased a SDHC maxmum 4GB and it wont formatt is there an solution round this at all?
Get another memory card. The C360 works with SD and MMC cards, not with SDHC cards. While an SDHC card will fit into the slot, it is electronically incompatible.
Mar 27, 2011 | Kodak EasyShare C360 Digital Camera
C360 will not format 4gbsd card
The C360 uses MMC and SD cards. Your 4GB card is actually an SDHC card. While SDHC cards will fit into SD devices, they are electronically incompatible and will not work. You need to use SD cards 2GB and smaller.
Dec 24, 2010 | Kodak EasyShare C360 Digital Camera
I cannot format my brand new memory card in my Kodak Easyshare.
The I would have to say bad card. Do you have another to try?
May 11, 2009 | Kodak EasyShare C360 Digital Camera
Cards not working with camera
If you used the SD/MMC memory card in another brand of camera or device, you may need to format the card in your new EasyShare digital camera. (You may have noticed a "Memory Card Needs Formatting" message when you inserted the card.) CAUTION: Formatting deletes all pictures and videos, including those that are protected. Removing a card during formatting may damage the card. To format the SD/MMC memory card or the internal memory of the camera: Transfer images to the computer before formatting the memory card. Press the camera Menu button. Highlight SETUP MENU, and then press the OK button. Highlight FORMAT, and then press the OK button. Highlight an option - MEMORY CARD (deletes everything on the card), CANCEL (exits without formatting), or INTERNAL MEMORY (deletes everything in internal memory). Press the OK button. Highlight Continue, and then press the OK button. Wait until formatting is finished before removing the card. When formatting is complete, the SETUP MENU is displayed. Press the Menu button to exit the menu.
Aug 29, 2005 | Kodak EasyShare C360 Digital Camera
"Memory card requires formatting"
This error message means that the card is corrupted or formatted for another digital camera. Turn off the camera. Insert a new card or format the card. CAUTION: Formatting deletes all pictures and videos, including those that are protected. Removing a card during formatting may damage the card.
Camera doesnt recognize a Secure Digitalor MultiMediamemory card?
The cause and solution may include one of the following: The card may not be certified SD or MMC. Purchase a certified SD or MMC memory card. The card may be corrupt. Reformat the memory card. CAUTION: Formatting deletes all pictures and videos, including those that are protected. Removing a card during formatting may damage the card. The card is not fully inserted in the camera. Turn off the camera, insert a card into the slot, then push to seat it.
Kodak EasyShare C360 Digital Camera Logo
80 people viewed this question
Top Kodak Cameras Experts
Muntejaya Ginting
Muntejaya Ginting
Lee Hodgson
Lee Hodgson
Marvin
Marvin
Are you a Kodak Camera Expert? Answer questions, earn points and help others
