There are two things that cause freeze up's...
Low air flow...
Low freon...
First check the filters, the blower , and the air vents to make sure that the air handler unit can move enough air...not enough air across the coil, the coil gets too cold, ice forms....
The low freon problem will require professional assistance...
For the system to be low there needs to be a leak...the leak must be found and repaired or the fix will only be temporary...
To do this the system refrigerant must be recovered, the leak fixed and then the system vacuumed and recharged...
One other thing....outdoor air temperatures under say 65 F can also cause freezing.... but I am assuming that you are above that if you are running your A/C system.
AirConditioner Trouble - Review the Possibilities
heatman101
