Question about Xerox CopyCentre C20 Black and White Copier
How to unlock scanner - Xerox CopyCentre C20 Black and White Copier
Please solve the problem of 5600/5650 usb scanner please verify that you have UNLOCKED the scanner hardware . The lock is located on the bottom of scanner click ok after you have unlocked the scanner
I have a scanner 5600/5650 UMAX , but it has been started problem since last one week and the scanning of document can not be possible give me solution
May 11, 2012 | Umax Astra 5600 Scanner
Bc898t all 500 channels are locked out. How to unlock all of them
Locking/Unlocking Banks When you are scanning conventional banks, the scanner displays the digit corresponding to all unlocked banks. To lock out a bank so that the scanner does not scan its channels, press the letter that corresponds to the bank. The bank's letter disappears from the display. To unlock locked-out banks, simply press that bank's letter again. The bank's letter appears on the display and the scanner includes that bank when scanning. Note: You cannot lock out all banks. One bank must be unlocked at all times. Locking/Unlocking Channels To lock out a channel so that the scanner does not stop on it while scanning, press L/O when the scanner is stopped on that channel, or manually select the channel and press L/O. To unlock the channel, manually select it and press L/O again.
Mar 29, 2011 | Uniden BC898T Base Scanner
Dell a940 AIO makes noise as soon as i turn it on then displays unlock scanner - tried to but will not unlock
Found this: http://support.dell.com/support/edocs/systems/a940/a940en1.pdf
Page iv identifies the location of the scanner lock
Page 44 contains the following
• You unlock the scanner bed. For help locating the scanner lock, see the picture of the printer on page iv.
Page 51 contains
Unlock Scanner message
The scanner is locked. To unlock it:
1 Press Power to turn the printer off.
2 Use both hands to lift the printer (scanner unit) until the scanner support
holds it open.
To the left and beside the scanner support is the scanner lock. For help, see
page iv.
3 Pull the scanner lock toward you to unlock the scanner.
4 Using both hands, lift the printer (scanner unit).
5 Push and hold the scanner support back.
6 Lower the printer (scanner unit) until it is completely closed.
7 Press Power to turn the printer back on.
Hope it helps.
Oct 25, 2009 | Dell A940 All-In-One InkJet Printer
Unlock scanner
lift up the scanner assembly to expose the underside of the scanner. slide the locking clip up from the locked position to the unlocked position. ( red )
Sep 25, 2008 | Lexmark X5150 All-In-One InkJet Printer
Scanner locked - unlock scanner
To unlock a scanner open it where you would put cartridges in and look for a red or green colored tab hanging down. There should be a little picture of a padlock. You can switch it from lock to unlock. It's kept locked to protect the scanner during shipping.
Hope this is helpful...
Jul 14, 2008 | Lexmark X340n All-In-One Laser Printer
Visioneer 9000 Scanner Unlocked ????
  1. Toggle the lock switch on the scanner leaving the switch in the unlocked (open padlock) position.
May 26, 2008 | Visioneer OneTouch 9000 Flatbed Scanner
Lexmark x5150 scanner locked
The scanner is locked. to unlock it
1. Press Power to turn the All-in-one off.
2. lift the scanner unit until the scanner support holds it. To the left and beside the scanner support is the scanner lock
3.pull the scanner lock toward you to unlock the scanner.
4. close the scanner lid.
5. power on.
Feb 19, 2008 | Lexmark X5150 All-In-One InkJet Printer
Dell A940 - Unlock Scanner then press power
See
Page 51 contains
holds it open.
page iv.
Dec 08, 2007 | Dell A940 All-In-One InkJet Printer
Xerox CopyCentre C20 Black and White Copier Logo
48 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Tareq Bin Mostaq...
Tareq Bin Mostaq...
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
