Question about Konica Minolta Imaging Unit 950-472 7915/7920 Black
Konica 7920 .. does not be recognized as a suitable IU, but it is a original Konica IU, even the IU-Nr. is displayed in Service menu...
Norman J Weimar Jr
  • Konica Minolta Master
  • 6,960 Answers
Sir/ Mam,
The image unit could be bad. take alcohol and clean all metal contacts on the outside. Then reseat. GET a second one.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Posted on Jan 01, 2015
Konica minolta bizhub 350 error c2557 setelah ganti toner. Help me, please....
Code
C2557
Description
ATDC Sensor Failure
- The scanning value of the ATDC Sensor is less than 7 % while the IU Motor is turning.
- The scanning value of the ATDC Sensor is more than 19 % while the IU Motor is turning.
Remedy
1 Check the UN2 connector for proper connection and correct as necessary. 2 Remove the Developing Unit from the IU, and then replace UN2. 3 Run F8. 4 Change PWB-A. 5 Change PU1N.
Jul 27, 2017 | Konica Minolta Office Equipment & Supplies
How to reset konica bizhab 164 m2
press menu quick setting << quick setting <> (service mode) go to service choise and go to maintenanc 0 ok press back IU LIFE STOP MODE press continues . press back go to clear data go to maintenac clear and supplies clear ok power off and on
May 31, 2014 | Konica Minolta Office Equipment & Supplies
How do I clear maintenance call M2 in copier Ineo 165
menu stop 00 stop 01 go to service choise go to maintenanc 0 presss back go to iu life stop mode press continues and press back sit down to clear data go to maintenanc clear prees ok and supplies clear and press ok .powe off and on and isssss okk :)
May 26, 2014 | Konica Minolta Office Equipment & Supplies
Konica minolta bizhub c200 erroe codes c255c
Black Imaging Unit Failure.
remove-shake-and reinstall black IU
Replace IU-K, if not then PRCB faulty.
Feb 03, 2014 | Konica Minolta bizhub Office Equipment &...
How to solve konica minilta c224 machine c2558 error
SHAKE THE BLACK IU VERY WELL Clean Imaging Unit Contacts RUN GRADATION
UPDATE FIRMWARE
REPLACE BLACK IU
Jun 29, 2013 | Konica Minolta Bizhub C224 Color Copier...
Konica minolta bizhub c450 error code c-2555
Yellow Imaging Unit Failure.
Take out IU-Y, shake it, check the toner layer, Re install it.
and see if improvement, else remove IU-Yellow
May 06, 2013 | Konica Minolta bizhub C450P Laser Printer
I want to change the setting of my drum unit on a konica minolta C-360
Enter in the service mode by press following keys:
Utility - Meter count-Check details - Stop - 0 - 0- Stop - 0 - 1 - Stop -0 -C - setting IU life stop setting and select NO STOP.
Feb 20, 2013 | Konica Minolta bizhub C250 All-In-One...
How to enter service mode konica minolta magicolor 7450
1. Display [SERVICE MENU] on the menu screen and press the MENU/SELECT key.
2. [ENTER PASSWORD] message is displayed.
3. Set first digit of password with the up key??/down key?? and press the right key??.
4. Repeat the above procedures to set up to seventh digit of password.
Enter "KMM7450" for service password. Press the MENU/SELECT key.
5. Press the MENU/SELECT key.
Jun 20, 2012 | Konica Minolta magicolor 7450 Laser...
Konica Minolta Imaging Unit 950-472 7915/7920 Black Logo
66 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
carpediemweb
Level 1 Expert
George Mclaughlin
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
