How do I replace the line in the door? It's broken and brittle
If you're handy and patient, you can rake the water unit apart, and replace the line. Start with ancopy of the specs. Here's an example of where you can download a free copy of the document.
http://kitchen.manualsonline.com/manuals/mfg/ge_appliances/tpx24pbdcc.html?p=31
I suggest you make it a habit of taking pictures of your work progress. It will help when you're putting it back together.
Good luck.
SOURCE: water dispenser line leaking at bottom of freezer
if you have enough room left you can just cut out the hole and go to any hardware store and pick up a water line coupler and repair it....if it is too short or broke up inside the door then you need to remove the water/ice dispenser and pull the line through and run the new one down the track.
SOURCE: Water supply line to in door water dispenser is
this is a problem that can only be solved by a professional so please get your local repairman on the line and have him come and take a look.
