Question about Fender Hot Rod Deluxe Guitar Combo Amplifier
Does anyone make a point to point kit for a hot rod deluxe?
Posted by deafcat1964 on
  • deafcat1964 Jun 24, 2009
    I've looked at their site. They want almost twice the price I paid for the amp for the kit alone! any other suggestins?
taran_2005
  • 10,515 Answers
There are so many sites.
One would be :-
http://www.torresengineering.com/
Thanks.
Posted on Jun 24, 2009
  • taran_2005
    taran_2005 Jun 24, 2009
    Thanks for giving me this rating!!!
    I can help other customers and get better rating than helping you and still getting nothing......!!!
    I apologize, keep searching.
    Thanks!!!!
You have to ask the question for us to try to get an answer.
Jul 17, 2014 | Fender Hot Rod Deluxe Guitar Combo...
Hot Rod Deluxe
Most likely clipping. This happens when the source DBs are too high for the amp....feeding in too hot.
Crate three button foot swich how do you connect it to the amp
The Fender Hot Rod Deluxe shows a 2-button footswitch as standard but I'm confused. This link shows it as connected to the amp via a mono cable ... FENDER Hot Rod Deluxe DeVille Footswitch which is impossible using two switches. Normally it's a stereo (tip, ring, sleeve) with tip to sleeve being one connection, and ring to sleeve the other. Good luck with this one.
Apr 22, 2014 | Fender Hot Rod Deluxe Guitar Combo...
Sometimes the reverb works, then next day it dont.i have a 1999fender hot rod deluxe
Fender Amplifiers are notorious for their reliability issues.However, I'm sure that amp will sound sweet once you get everything working again!
The problem is likely your "tank". The tank contains the springs which create reverb as the guitar's signal is sent through them. A broken spring could be causing your problem.
Luckily, any of the larger music stores should have them avalible.
Good Luck!
-Sheeves
Mar 02, 2011 | Fender Hot Rod Deluxe Guitar Combo...
Fender hot rod deluxe static
This often due to a cracked circuit board or bad solder joint. Sometimes input connectors are bad but those are easily discovered by wiggling the plug.
Jul 12, 2010 | Fender Hot Rod Deluxe Guitar Combo...
Fix Reverb unit on Fender Hot-Rod Deluxe Amp
Could have broken a spring in the reverb tank, or a wire connecting it to the amp, or the reverb driver tube, or a few other things, but those are the most likely in this situation. Thats what I'd check first. Give it a little slap and if it vibrates like normal, your spring is probably ok, you can still open it up and double check though. Check your wires. Then pull your reverb driver tube and replace it. If that doesn't work, it is probably in the circuit somewhere, and you should not work on your amp unless you know what you are doing. They store large amounts of electicity in the caps and they can kill you.
Apr 24, 2010 | Fender Hot Rod Deluxe Guitar Combo...
I have a Fender Hot Rod Deluxe. It has very few
First try turning the volume control down before turning switch to operate.
IF this seems to fix it, IF the unit has a tank reverb, the vibration of the reverb springs MAY be causing the problem. The solution then is to reduce the volume before applying power WHICH is a good idea anyway... from an electrical engineer.
Jul 24, 2009 | Fender Hot Rod Deluxe Guitar Combo...
Fender Hot Rod Deville 212 - popped and died
This may sound stupid, but did you check the fuse?
Apr 22, 2009 | Fender Hot Rod Deluxe Guitar Combo...
Fender Hot Rod Deluxe Guitar Combo Amplifier  Logo
122 people viewed this question
Top Fender Music Experts
Larry Stiles
Larry Stiles
Marvin
Marvin
Are you a Fender Music Expert? Answer questions, earn points and help others
