Question about Chevrolet 1992 Chevrolet Blazer S10/jimmy S15 Radio
Why am i getting bad feul pressur?
92 chevy s10 blazer 4.3 vortec not getting good fuel pressur replaced feul pump feul pump relay and pig tail its not leaking feul anywhere could it be a bad computer also replaced distributer and i know it is out of timenot sure if that would mess with the feul pressur
5 Related Answers
Anonymous
SOURCE: 1991 chevy s10 blazer
Check the fuse under the dash. Did you replace the inline fuel filter? If not, you could loosen the line going into the filter then turn the key to the on position. The pump should run for about 2 seconds then the relay should kick off. Turn off the key for approx. 5 seconds then cycle key back on and the pump should cycle again. If you get a 2 second burst of fuel each time then the pump is cycling. Install a new fuel filter and check the grounded wire by the tank. Hope this helps. :)
Posted on Nov 03, 2008
GM Elec
Bruce Bracey
  • 1000 Answers
SOURCE: 92 Chevy Suburban Electrical Fuel System
I assume the fuel pump fuse is good?
The only time voltage will be sent to the fuel pump will be the first 2 to 3 seconds if the starter is not engaged. You will want to crank the engine over and check for voltage on the load side of the relay, circuit #30 at the relay.
Let me know after you check.
Regards,
Posted on Feb 23, 2009
Anonymous
  • 116 Answers
SOURCE: 1999 chevy blazer wont start
THE FUEL PUMP IS BAD.
if your losing fuel pressure after the pump runs the drain back valve in the pump has failed.
and i doubt that you are seeing enough fuel pressure to run a vortec engine.
low fuel pressure equals a non running vortec
Posted on Apr 11, 2009
Anonymous
  • 139 Answers
SOURCE: fuel pump pressure specs
The fuel pump specs are 14 psi. and 20 gallons an hour.
Posted on Sep 08, 2009
Anonymous
  • 541 Answers
SOURCE: My 4.3 vortec engine in my s10 blazer won't start
try the ignition module. if it is bad it does not send the signal for the the throttle body injectors to spray feul.
Posted on Oct 23, 2009
I have a 92 chevy blazer 4.3 vortec eng. central port injection not tbi it has no injector pulse do you think its the cam sensor?
Not likely. The cam and crank sensor inputs are required for the ECM to provide spark. The fact that it starts with starting fluid would lead me to believe that those signals are present. You say there is no injector pulse. Did you test this? Or are you assuming that since you have fuel to the injector, but not into the cylinders? CPI systems only have one injector and they can fail. Also, while fuel may be present, if the pressure is not sufficient, the system will not operate. Here is a link describing the system and things you can check to diagnose problems. Lastly, the ECM itself could be the problem....
GMC Chevy Light Truck Central Port Fuel Injection Diagnosis
Jan 12, 2016 | 92 1992 Chevrolet S10 Blazer 4.3L V6...
I have a 2003 Chevy blazer with a 4.3 vortec motor it has a small leaking head gasket how long can I drive it until I have the money to fix it.
Troubleshooting a Blown Head Gasket (GM 4.3L, 5.0L, 5.7L)
troubleshootmyvehicle.com > GM > 4.3L, 5.0L, 5.7L
Mar 28, 2011 - There are so many ways to test for a blown head gasket on your 4.3L, 5.0L, 5.7L GM van (or mini-van, pick up, SUV) that it can get confusing.
Chevy Blazer Coolant Leak (Intake Manifold) - YouTube
? 4:33
https://www.youtube.com/watch?v=SC4VXdt5wiE
Oct 9, 2013 - Uploaded by eyetotheworld
I have localized a coolant leak on my 2003 Chevy Blazer to thegasket of the intake ... Turns out that this is common among this particular engine both in the v6 & v8 sizes. ... The guy has been generous to detail his projects. ... 98 S10 Vortec V6 4.3 IntakeGasket Replacement Part 1 of 5 - Duration: 18:17. by ...
Chevy 4.3l v6 oil leak issue 2001 Xtreme Blazer - YouTube
? 6:11
https://www.youtube.com/watch?v=Y8Ogd5voIYs
Nov 12, 2011 - Uploaded by smiatacz
This darn little engine just keeps going. ... I have a 2003 chevy blazer and the oil cooler line from the oil filter to ... I have a 95 Chevy s10 v6 vortec 2wd that is slightly dripping oil out of agasket ... I'm having same problem 2001 Chevy Blazer 4x4 (not xtreme) not sure if those same bolts are missing on mine.
Dec 28, 2015 | Cars & Trucks
93 s10 blazer with 4.3 liter vortec won't stay
You first need to run a fault code test on this engine, to do that go here.
Oct 10, 2012 | Cars & Trucks
I have a 92 chevy s10 blazer 4x4 4.3 vortec W i just replaced the fuel pump and fuel filter.. it will start sometimes mainly after it sits overnight but when you drive it you can only drive for about 10...
I had this problem.I removed the fuel pressure regulator and it was full of carbon.Remove it very carefully as to not damage any seals.Remove as much carbon as you can and reinstall.This should solve your problem.
Nov 30, 2009 | 1992 Chevrolet S-10 Blazer
I have a chevy blazer 94 S10 still quit on the road.
How is it running before it quits onyou. This could be the culprit of an egr valve. How many miles on thevehicle. The egr seems to die on a certain mileage pattern. Also youcould start by cleaning the egr valve before replacing it. This couldvery well help the situation, but this is just a guess. Hope thishelps!!
Apr 30, 2009 | 1994 Chevrolet S-10 Blazer
Apr 11, 2009 | 1999 Chevrolet Blazer
My 94 blazer wont start
I have the same problem with my 95 blazer I have heard that it is the fuel pressure regulator. That is the next part I will be replaceing.
Good luck to all.
If any one finds any thing out please let me know!
Dec 13, 2008 | 1994 Chevrolet S-10 Blazer
Chevrolet 1992 Chevrolet Blazer S10/jimmy S15 Radio Logo
Top Chevrolet Audio Players & Recorders Experts
Marvin
Marvin
Lawrence Oravetz
Glenn Smart
Glenn Smart
Are you a Chevrolet Audio Player and Recorder Expert? Answer questions, earn points and help others
