Question about Kodak i1220 Pass-Through Scanner
Kodak I1220 My scanner Kodak I1220 don't start, only the red light is burning.
Posted by scorpel on
Anonymous
    New Friend:
Kodak i1210 the red led is flashing and no work
Posted on Mar 26, 2010
Anonymous
    New Friend:
    Problem Solver:
  • 7 Answers
Make sure that the scanner is connected to the pc. if the scanner only ahs the red light and no other lights on the scanner come on then you will need a replacement scanner - contact the tech support to arrange this
Posted on Dec 11, 2009
Tareq Bin Mostaq Mostaq
    President:
  • Kodak Master
  • 1,449 Answers
You change your printer cartridge then solve your problem
Posted on Jun 24, 2009
Need i1220 license
There is not a "license" to use a i1220 scanner. If you are referring to a license needed for Kodak Capture Pro software, then contact 1-800-822-1414 for assistance with acquiring a license.
Apr 08, 2014 | Kodak i1220 Flatbed Scanner
I just received my i1220. After it powered up the light that comes on is constant red. The light does not go green.
What software are you using?
Have you installed the TWAIN driver for your operating system?
Jan 08, 2011 | Kodak i1220 Pass-Through Scanner
Problems with Kodak i1220 Smart Touch software
Go into C:\programdata\ and remove the kds_kodak folder. It may ask you to skip files it can't delete. Just click skip for all of them (probably around 15 files). Then reboot your computer and you should be able to scan.
Jan 23, 2010 | Kodak i1220 Pass-Through Scanner
Kodak I1220 is connected but can not be started by button nor smart touch
update the driver and the smart touch driver from the kodak website. make sure that the scanner is not connected when you do this. if this does not resolve the problem, then contact the kodak scanner support call centre as this could be a problem deeper within the pc
Nov 09, 2009 | Kodak i1220 Pass-Through Scanner
Red and green lines through prints from a kodak
clean the scanner with anti static wipes and vacuum clean the scanner, if this does not work then call the kodak techs again and they can send a cleaning kit or a replacement scanner. the lines are caused by dust in the scanner
Aug 06, 2009 | Kodak i1220 Pass-Through Scanner
Kodak i1220 Pass-Through Scanner Logo
2,432 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Muntejaya Ginting
Muntejaya Ginting
efs_perpends
efs_perpends
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
