Question about Amana SXD524VW Side by Side Refrigerator
I needs the wiring diagram for a side by side amana forefinger actor. Model number ARS2364AC....I need to wire the circulating fan
3 Related Answers
Anonymous
SOURCE: Amana side by side
not going thru defrost cycle
Posted on Sep 14, 2008
SOURCE: the freezer is cold but not cold enough to make ice
Check the back (interior) lower half of the freezer wall. If you see a frost build up, you either have an issue with your defrost cicuit (timer, heater, thermostat) or the evaporator (freezer) fan is not running. If there is not a frost build up on the back wall you either have a sealed system (weak compressor, leak or restriction) problem....or the condensor fan motor is not working. This would cause the compressor to overheat and shut down until cooled, and prevent the deep freeze.
Posted on Jun 05, 2009
Anonymous
  • 999 Answers
SOURCE: I am looking for a wiring diagram for the Amana
Look behind the toe plate for the tech sheet. Hopefully it was not removed with the packing materials. If it is missing try here
http://www.apwagner.com/index.php?main_page=product_info&products_id=566096 the part number is RT1300013
Posted on Oct 12, 2009
Wiring schematic goodman ph036a serial # 9610058720
Is condenser running? Verify amps to be sure both fan and compressor are operating. Should have 2 wires to compressor and 1 to fan on top of contactor. Then on the capactor (herm) terminal is the remaining compressor wire. On fan and c would be the 2 remaining wires for the outdoor fan motor. Then 1 more wire on c that jumps to the top of the contactor on the other side to which the first fan wire connects. GOOD LUCK.
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Mar 19, 2017 | Goodman Heating & Cooling
Fan oven will not turn off can only isolate at switch on wall all other switches working
Hello Eamon;
My name is Peter. I am a retired field service appliance technician.
The identity number that you provided is not a model number. If you took it off your user manual it is not the model number.
I need your model number. It is located on a label on the face of your oven or on the side of your oven door.
Send me your model number so I can look at the wiring diagram.
Your oven fan runs for 2 reasons:
1.) To circulate the hot air in your oven.
2.) To vent the hot air in your oven when the heat is too hot.
Send me your model number so I can see what you have and help you.
Mar 07, 2016 | Whirlpool AKZ 515 Double Oven
Need wiring diagram for side by side
You will need to post your model number.
Aug 03, 2011 | Amana Refrigerators
Amana refrigerator is not cooling
I don't think vacumming the coils will help at this point... you have bigger problems then that...
Here are a couple of tips that will give you some things to check out...
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Apr 17, 2010 | Amana ARSE665BS Side by Side Refrigerator
Evap fan won't run but is good and will run when hot wired. Compressor runs but cold air does not circulate through frig side nor freezer. Could defrost heater or timer keep fan from running?
There is a thermostat inside the freezer that is wired in series to the fan more then likely it is bad. Looks like a round disk located on the side of the evaporator coils. If it is puffed up looking it is bad. About the size of a 50 cents piece.
Dec 07, 2009 | Amana Refrigerators
I am looking for a wiring diagram for the Amana Side by Side Refrigerator/Freezer model number is SRD22S5L
Oct 11, 2009 | Amana SXD524VW Side by Side Refrigerator
The freezer is cold but not cold enough to make ice
Jun 05, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Refrigerator wont circulate cold air
Couldnt find anything on you model #... Might try jumping out the door switch... some refrigerators the door switch will stop the fan motor.. if you have a wireing diagram post on here.. some refrig. have one tugged under front .. some hard to find if any
Aug 30, 2007 | Amana ARS9266BS Side by Side Refrigerator
Amana SXD524VW Side by Side Refrigerator Logo
Top Amana Refrigerators Experts
Dan Webster
Dan Webster
Jay Finke
Jay Finke
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
