Question about NorStar M7310 Phone
Someone in the office turned off the microphone how do you turn it back on
Number are the pod to set turn
I know what you are asking now. Open the radio and look for the modulation transformer towards the back of the radio. see the variable resistor closest to it,turn it all the way to the left while talking to someone and if they loose you then turn it all the way to the right. Put the lid back on and you're done.
Mar 11, 2016 | Cobra 78x 40 Channel Cb Radio With...
Less than a year my church purchased wireless microphones suddenly not working there is no sound coming out of microphones. HELP!!
What does the receiver go into ?
a pre amp mixer ?
What are the volume levels set at on the mixer for the receiver input ?
Also check if the pre amp goes into another amplifier that the volume setting on the final amplifier device if used have not been turned down.
Bet someone has fiddled with these settings of volumes !
Aug 23, 2015 | Pyle Pro PDWM5000 4 Mic VHF Wireless...
Why would my laptop speakers randomly start screeching like at a concert when someone turns on a microphone?
Usually means that your settings are set to broadcast (or listen to) your microphone... If the sound from your speakers is being picked up by your mic, and your speakers are outputting the sound from your mic, it will manifest itself as a lot of wailing.
either turn your speakers down, or disable the setting that makes you be able to hear whatever sound is coming from your microphone (it's a checkbox labled "listen to this device" in most modern windows sound configs)
some drivers have a echo reduction option, turning this on may also help
Jan 11, 2014 | IBM ThinkPad Computers & Internet
Can't access missed calls, lost my instruction book, need one. Also I get missed calls when I'm sitting right beside the phone. It never rang.Could I talk to someone?
If this is a Panasonic phone connected to a phone system as in an office setting, sounds like the ringer has been turned off. Get someone to call your phone and while they are calling turn the jog dial to turn the ringer back on or use the LCD intertactive keys to turn the ringer back on.
Dec 08, 2010 | Panasonic Lands Phones
Turning on microphone on a advent 4489
Check the audio controls in advanced mode. There may be a check in the mute area for your microphone, or the micophone might not be installed at all. It is in your control panel, but may be located differently based upon whicih version of Windows you're using.
Jun 12, 2009 | Computers & Internet
Logitech microphone
have you checked the settings under control panel/sounds and audio devices?
open that up click the voice taband under voice recording press the volume button, check to see if the check box has a tick in it under microphone and that the volume is turned up. try the test hardware button to test your mic and adjust the levels from within the wizard.
hope this gets you headed in the right direction
Apr 23, 2009 | Computers & Internet
Buzzing from the microphone
Normal 0 If you have your speakers turned up it will cause you to get feed back or a squealing sound. Turn down the speaker level or better yet use a headset and this will no longer be a problem.
Hope this helps. Bud
Apr 08, 2009 | Computers & Internet
The devise does not hear my voice what should i do?
The first step is to go into your volume control panel and check to be sure that the microphone fader is not muted and is turned up. Also, what application are you attempting to talk to someone with -- telphone, IM chat, game chat?
Apr 12, 2008 | Labtec Desk Mic 534 Consumer Microphone
How do I turn off the intercom to my phone
Hi Andrew,
Press [feature] [8] [8] to prevent your phone from receiving the intercom
Brian
Apr 01, 2008 | NorStar M7310 Corded Phone
NorStar M7310 Phone Logo
Top NorStar Lands Phones Experts
Marvin
Marvin
Lee Hodgson
Lee Hodgson
Are you a NorStar Lands Phone Expert? Answer questions, earn points and help others
