Question about Yamaha Rx-v465/rxv465 Home Theater Receiver
I have sound on my Yamaha RX-V465 but no picture on the TV screen
I have connected the HD PVR decoder with an HDMI cable to my RX-V465. I run another HDMI from the same RX-V465 to my Samsung TV. I get the sound but no picture on TV.
5 Related Answers
Anonymous
  • 5 Answers
SOURCE: yamaha rx-v1800
I think the Yamaha will not upconvert anything below 480p through the HDMI output. You'll need to use the component out to the TV.
Posted on Aug 12, 2008
Anonymous
  • 4 Answers
SOURCE: tv speaker noise from yamaha rx-v663 hdmi connection
try running your A/C from TV to your reciver swichd outlet sound like it could be a grounding problem.This will put all ac from same outlet to the same componets.And will elimanate any difference in potencial
Posted on Feb 23, 2009
Koobiidoobii
  • 3 Answers
SOURCE: I would like to hook up my components without
You should not lose any picture quality from the DVD player. I am currently having the similar setup with PS3 as the Blu-ray DVD player with HDMI and a Samsung DVD as regular player with component cable to a Samsung LCD TV. Remember the quality on Blu-ray is better than normal DVD so don't expect more than what it is.
Posted on Oct 18, 2009
Anonymous
SOURCE: Hi, I have a yamaha rx-v465 av receiver and have
I need a connection Diagram for the RX-V465 Yamaha receiver
Posted on Dec 30, 2009
Marek Podmaka
  • 127 Answers
SOURCE: RX-V465 Yamaha Reciver we can get picture but no sound w/PS3
Check HDMI Sound settings:
Enter Setup menu via remote, then Func. Setup / HDMI / Audio. You can choose from Amp (sound will be played via Yamaha), TV (sound will go straight via HDMI out to your TV and not play on Yamaha) and Amp+TV (Yamaha will play the sound and also pass it to the TV).
Also what is your source? DVD or some network player? For example Yamaha cannot decode audio in AAC or other computer formats, so be sure to change the audio settings of your player to output PCM and not raw/bitstream.
Posted on Apr 27, 2010
The Yamaha Reciever RX-V465 is connected to my digital TV by fibre optic cabel. I have sound when I connect my MP3 to the V-Aux and the speakers are displayed on the display window of the Reciever same as...
Please check your TV settings and the optical cable.
The speaker icons disapper from LCD display when the receiver does not detect any input signal throught the optical/coax/hdmi cable.
3answers
Yamaha av Receiver RX-V465 picture but no sound. Can switch between PS3 and sat tv all via hdmi connections. Good picture yet still no sound. Trying to run left right and center Bose speakers. Read the...
Check the settings on receiver in the SETUP menu / HDMI / Audio. Here you can choose Amp (sound goes from the speakers connected to receiver), TV (receiver is muted and sound is routed via HDMI to TV) and Amp+TV (sound goes from speakers and also to TV).
Also check in OPTION menu / Signal Info that receiver is receiving sound in recognized format.
1helpful
2answers
Satellite Receiver to Yamaha Receiver
It sounds like either on the 612 or the Yamaha Receiver that the HDMI port is faulty, thus causing the flashing picture. It sounds like the 612 to the TV works fine. I would recommend replacing the Yamaha, and if problem persists then try replacing the 612.
Haveing trouble syncing the sound with lips is there a trick to do this? also whats the best setting to get the best true surround sound by the way i have Rx-v465 with klipsch 300 home theater speakers.
RX-V465 has auto-sync feature over HDMI. So if you have your DVD and TV connected over HDMI, receiver will communicate with your TV and set the delay automatically based on TV processing speed.
You can turn auto-sync on in Setup menu / Sound Setup / Lipsync / HDMI Auto.
Or if that doesn't work for you, you can set a value in milliseconds manually in the same submenu.
3helpful
I would like to hook up my components without having to turn on the receiver to watch tv from DVR or Cable if possible. I have Scientific Atlanta Explorer 8300 HD Cable DVR w/HDMI out, Samsung TV w/HDMI ,...
Tv speaker noise from yamaha rx-v663 hdmi connection
1helpful
Yamaha rx-v1800
Open Questions:
See all Yamaha Rx-v465/rxv465 Home Theater Receiver Questions
Yamaha Rx-v465/rxv465 Home Theater Receiver Logo
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Muzahura Frank
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
