Question about SanDisk Sansa e260 MP3 Player
Songs do not appear on WMP11
All songs sync to e260R fine; however, they do not appear on the WMP11. The PC does not "re-sync" them because the songs are on the e260R. If you click on the "Sync Results" on the WMP11 screen, they do appear there, but that doesn't give you a "real look" inside the e260R. If you click on "Songs", they do not appear there. What the...?
Posted by cae2544 on
  • cae2544 Nov 05, 2007
    I used the same PC about 5 minutes after installing the songs. Also, Sansa talks about MSC mode vs. MTS mode. You are supposed to be able to find it under USB>. Well... does not exist in on my e260R. Whatsup?
  • Anonymous Jan 09, 2008
    I think that it could be a SanDisk typo, if you're talking about what I think you're talking about, then you could be talking about the Rhapsody vs. PlaysForSure format.
    You can access this option through , and then .
    Hope this helps.
Timothy D
  • 626 Answers
If you did not transfer the music with same copy or version of Windows Media Player that you are trying to view them with, you cannot see them.
Its a Windows problem, not the device.
You can view the contents in My Computer>Device Name (e260)>MUSIC folder and manually add or delete files that way.
Best of Luck.
Posted on Nov 05, 2007
How do I get the downloaded music from my computer into the clip?
You have 2 ways to transfer your songs from your computer to your sansa clip:
1. Plug sansa clip to computer, double click on "Sansa Clip ...GB", double click on "Internal Memory", you will see the file "Music", copy your songs and paste them into Music file of the device.
2. Using Windows Media Player: open windows media player, plug sansa clip into computer, click on Sync tab, select songs that you want to sync, drag and drop song selected into "Sync list" on the right side of the windows media player (you should update wmp11), then click on button Start Sync.
Good luck
Jan 24, 2010 | SanDisk Sansa Clip MP3 Player
Lookins for software
HDD14xx GoGear:
manual
software and drivers
The manual shows how to make lists and transfers with your player.
A short guide on how to use Windows Media Player 11:
1. Have WMP11 always on top for "drag and drop" usage
Right click in the head of the WMP11 page:
in Tools > Options... > Player : select "Keep the player on top ..."
Restore Down the size of the WMP11 screen and adjust the size on the
edge(s) as you require for your screen.
2. in [Library] mode: under Playlists "Create Playlist" e.g. "My Playlist"
and Enter: "My Playlist" is added on the right screen side.
3. Open your music maps and ad songs by drag and drop method
onto the right saying "Drag items here"
4. when ready adding songs in [Library] mode: "Save Playlist"
5. in [Sync] mode drag e.g. "My Playlist" under the connected device
and "Start Sync": wait until al files have synchronized: a message
will show up when you can disconnect the player.
Sep 11, 2009 | Philips GOGEAR SA6045 MP3 Player
Playlist on go gear vibe
Using Windows Media Player 11 ?
Right click in the head of the WMP11 page: in Tools > Options... > Player : select "Keep the player on top ..."
Sep 11, 2009 | Philips Audio Players & Recorders
How to download songs
1. Are you using Windows Media Player 11 ?
2. Can you see the Sansa e250 connected in the sync mode ?
If no: install and update WMP11
If yes:
3. Make "new playlist" in the <Library> or <Sync> mode
of WMP 11; screen left side.
3.1 Save "new playlist" in WMP11; screen right side.
4. Put in <Sync> mode your playlist under the player: The player
should be connected showing in WMP11. Start synchronizing.
Leave the player connected until <Sync> is ready.
Support for Sansa e250:
http://www.sansa.com/sites/default/files/downloads/e200_userguide_en.pdf
Aug 29, 2009 | SanDisk Sansa e250 MP3 Player
Cant download music
The songs need to be formatted for a sansa. Use Windows Media Player 11. Don't use Rhapsody, too many problems.
Load a CD into your computer, on the Toolbar of WMP11 click rip, After all songs are ripped, hook up your Sansa to the computer via USB cable, Click Sync. WMP11 will not only sync the sansa it will sync the micro card also. You have your choice where you want to put the music. Drag and drop the music in the box to the left where you synced your sansa and at the bottom of the box click Sync. All music will be synced to your sansa or card which ever one you chose. Understand, when the sansa starts up, the card syncs with the sansa, you don't have to do anything. Try this and let me know how it works.
Mar 24, 2008 | SanDisk Sansa e260 MP3 Player
Sandisk Sansa e260r
Open Windows Media Player with the Sansa connected.
Open the Songs folder that is underneath the icon of the sansa player. Left-click a song, and hit the Delete button on your computer's keyboard.
Mar 21, 2008 | SanDisk Sansa e250 MP3 Player
Sansa e260R 4.0GB mp3 player
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/Retail/DriverDownloads.aspx
or
http://www.sandisk.com/DriverDownload/driverList.asp
-Tha Mp3 Doctor
Mar 13, 2008 | SanDisk Sansa e260 MP3 Player
Sansa mp3 e260
Just close it if you dont want WMP. IF what you mean is i dont know how to download songs then go to The SYNC tab on WMP but first make sure you are using WMP11 or Higher. After clicking the SYnc tab then Drag the song files to the empty spot below the playyers picture and clik The Load Songs button or Synchronize button. Hope this helpsl
Feb 17, 2008 | SanDisk Sansa e260 MP3 Player
Song Alphabetizer
The best thing to do is reformat it
Dec 02, 2006 | SanDisk Sansa e200 MP3 Player
SanDisk Sansa e260 MP3 Player Logo
96 people viewed this question
Top SanDisk Audio Players & Recorders Experts
ThaMp3Doctor
ThaMp3Doctor
Muntejaya Ginting
Muntejaya Ginting
Ekse
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
