Question about Orvis Encounter Large Arbor Fly Reels & Spools
How do you change the retrieve to left or right hand on a orvis encounter fly reel ?
I want to change the retrieve fro left to right hand
Gary Husslein
    New Friend:
Drag factory installed for left-hand wind. To change your real to right-hand wind, remove spool, pull the keyed bush and clicker plate assembly off the spindle. Flip the clutch bearing (silver) and reassemble.
Posted on Apr 09, 2015
Fishing pole is supposed to be for left and right hand use, but can only be used for left hand. How to switch to right hand
Hold the bell or (metal thing on the top) so that it doesn't turn and reel in. It should start unscrewing. Theres a cap on the other side, unscrew it and put it on the left hand side. Then screw the handle in on the right side by just reeling in until the bell starts spinning.
Jun 21, 2010 | Shakespeare Surf Fishing Rod and Reel...
Left hand retrieve
Unscrew handle put on other side .
May 12, 2010 | Scientific Anglers Scientific Angler...
I need to change the wind direction from left hand to right hand. In order to remove the e-clip from the spindle, what tool should I use to remove it with?
A pair ofs tweezers should do the trick, and some tape.
You might want to try tackleright.com for more help.
Hope it helps.
Sep 22, 2009 | Bauer Premium Fly Reels Toys
Orvis wood reel battery clock
Apr 05, 2017 | Home
Orvis Encounter Large Arbor Fly Reels & Spools Logo
2,813 people viewed this question
Top Orvis Fishing Experts
ray gallant
Andrew Taylor
Andrew Taylor
Steve P
Steve P
Are you an Orvis Fishing Expert? Answer questions, earn points and help others
