Good Morning Friend,
I understand that your Electrolux double oven, model# DD060GA, is having trouble with the bottom oven coming on. I also see that your top oven works just fine. This appears to be a UK Electrolux double oven. I suggest contacting the manufacturer directly. They will be able to better assist you in getting your bottom oven functioning correctly.
-Best Regards-
WP
SOURCE: Electrolux Icon Mystery issue
Check to be sure your racks are all slid in to the back. Are you getting a error code?
SOURCE: electrolux oven wont heat up after power cut
It may be necessary to actually pull the AC plug out and let it stew for a while.
Many electronic controls lock up with a loss, then return, of power.
SOURCE: Electrolux double oven does not get hot
If it is a fan assisisted oven and the fan is still working, then you need a new oven element fitting.
Plz rate my solution.
Thanks.
