Question about Ricoh Aficio Mp161 Copier Photocopier Copy Machine System Mp 161 Ricoh
Why dos the add paper light stay on despite there being paper in the paper tray.
Posted by Bernice K Romig on
Thomas Smithbrother
    Top Expert:
  • Ricoh Master
  • 3,698 Answers
The switch that says that the paper is out is stuck or misaligned.
Posted on May 22, 2014
Hp officejet 7000 won't print 6.5 x 10 paper size
Officejet 8620 printed about 400 for me in 16 months then stopped. A few weeks prior to the error msg. that the paper in the tray did not match my document settings another message said it did not recognize any paper in tray including letter size despite there being about 100 sheets. I c alled HP two different days, tried documents on a brand new computer, created a new document. Took two hours total and $20 to be told the printer did not support this paper size. I called them prior to purchase and told them my needs and was told it would accommodate the size. My local techie and I both think the sensors have gone bad in under 2 years as I had been able to print my cards with no issue about 400 times. I called Epson three different times and each tech support person says Epsons can accommodate this.
Aug 08, 2012 | HP Officejet 7000 Wide Format Printer...
The "add paper light" is on even though the paper
The light means that the printer is out of media, or the media did not feed properly
What you can do
-Load media into tray and press Continue button to resume printing.
-Check that the media is loaded correctly in tray
-Press Cancel button to cancel the print job.
Jun 29, 2011 | Lexmark E232 Laser Printer
Will not pick up paper from normal tray 1 but does pick up paper from larger paper tray 2 despite having error message that tray 1 is empty, it also has a duplexer fitted. If you put paper in tray1 it...
check the tray one paper empty senor blow out with air is the paper acturator broken that the device that would lay on the paper when its out of paper the sensor will drop far enough to tell the printer tray one is out of paper miss feed are the rollers are dirty and or need to be replaced
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Jan 14, 2018 | Konica Minolta magicolor 2490MF Laser...
Paper doesn't feed from inside on XD 100 work center (10 years old, lightly used). Despite a full paper drawer, I get the "out of paper" error message.  I can copy by feeding through the back.
On this machine, the feed rollers might be worn down.
Not seeing the machine and by the description. there can also be other possible problem areas, deep in the machine itself.
Does the paper feed partially out?
If it does not, are there paper black scuff marks where the rollers were trying to feed the paper.
Can you hear the solenoids feed the paper?
If the paper does feed and seems crooked, it is possible the paper tray springs need to be stretched out just a little to push the paper tray plate more on the feed rollers.
Make sure the tray is completely up in the latched position so the feed wheels will touch the paper stack itself.
If you have a two paper tray, make sure you tell the machine what size paper you have for each tray.
Run paper in each tray.
Good luck.
Jan 15, 2010 | Xerox Office Equipment & Supplies
I do not have a manual. What does supply REC. paper mean?
supply rec paper mean stay paper in copier cassette or that the paper print
it is mean insert paper in cassette
Dec 16, 2008 | Canon imageCLASS D320 Laser Printer
Our customer has a Canon Laser fax L800, Error message of Jammed paper displays, despite the fact that there is no paper jammed in the machine, paper path looks ok. Any ideas !!
Is it a jam or an add paper message (same light)? Sometimes you have to press the start button after you add paper on this machine.
Nov 27, 2008 | Office Equipment & Supplies
Could not pick up papers from paper tray.
1- either the tray is not lifting the paper to meet the rollers ( which may indicate a motor problem) or the rollers are not coming down to meet hte paper (clutch problem)
Aug 30, 2008 | Sharp AL 1631 Copier
Paper
then you have some buried deep inside..turn light off in office, close door, and use a flashlight or penlight..paper will glow from light..that will help a bit..then long tweezers to extract the fragments, eh?
http://tinyurl.com/6qcpgy
Aug 15, 2008 | Brother HL-2040 Laser Printer
Ricoh Aficio Mp161 Copier Photocopier Copy Machine System Mp 161 Ricoh Logo
147 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Ekse
Tareq Bin Mostaq...
Tareq Bin Mostaq...
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
