Question about Samsung SyncMaster 740N 17" LCD Monitor
Is it possible to turn off Power Saving Mode
SOURCE: Samsubg 17"LCD 740N monitor flickers
It sounds like the CCFLs (backlight lamps) in the monitor are failing. You might be able to get them replaced by the manufacturer if it's still within warranty. Otherwise the fix might involve an expensive technician and replacement parts.
Posted on Jun 10, 2008
SOURCE: Samsubg Monitor flickers
My samsung 740N lcd Monitor is flickering. can i get a solution of this problem?
Posted on Nov 05, 2008
SOURCE: samsung 740n not working
You have a monitor with a common problem. After a few years some LCD monitors
will blow a power supply. The problem is caused by parts called
capacitors overheating in the confined space of he monitor. If you are
good at electronics repair/soldering you can usually fix he problem. Check out a few pictures on my web site www.ccl-la.com/badcaps.htm
You can take the back cover off your monitor and look for the bad
parts, replace any that look like the pictues and your monitor should
work fine. The capacitors do need to be installed with the correct +
and - connections, note the stripe on the old one and insert the new
one the same way. If you don't want to try the repair yourself we offer
a repair service for $35 plus shipping. I hope this helps, if so please
rate my solution.
Buddy
Corporate Computer
Over 21 years of computer and printer support/repair
Posted on Jun 20, 2009
SOURCE: LCD Samsung Syncmaster 740n 17... Fuse F301 is brocken.
You still have shorted out components on the circuit board, you will need to download tha service manul here to do an indepth troubleshooting: http://elektrotanya.com/
Posted on Mar 30, 2010
SOURCE: Samsung SyncMaster 740N 17" LCD
The problem is in the power supply and inverter board, cause normally bad capacitors that sometimes bulge at the top indicating they are open.
Posted on Feb 21, 2011
