Changed secondary burner unit and thermister still not cold enough.
SOURCE: After having defrosted our fridge and started it
You need to check the temperature settings and see if there is enough air flow in the refrigerator and freezer. You need to check for air flow restrictions in the vents and clean the compressor coils. The door seals, door switch, defrost heater and timer has to be checked. Also clean the clogged drain tube and refrigerant leak.
Good luck in solving the problem.....
SOURCE: Fridge does not get cold during propane gas
According to the manual the following is the most likely items to cause that failure. But since it is only in the frigerator section and not the freezer section it could be the lower circuit board. LP Gas
Orifice
Flue Baffle
Flue Tube
Burner
Lower Circuit Board
SOURCE: Dometic DM 2612 the fridge will freeze
You will need the thermister repair kit. Take a look at this page.
All units have some type of defrost...
Check
out these tips...they can help you figure out what is going wrong
with your refrigerator
Refrigerator
not Cooling
or Fridge not Cooling
How to Defrost Refrigerator Defrost
Timer Problem
Water
Running in refrigerator
from Freezer
Refrigerator
or Freezer not Cooling or Getting Cold
heatman101
