Question about Waring Pro WO50 Cordless Wine Opener
Won't pull cork out
Does matter if plastic or cork, goes in won't pull cork out
Posted by Lane Lewis on
John Ray
  • 790 Answers
Battery may be soft. N/G
If it goes in with No Problem and will not pull out
Posted on May 21, 2014
Cork stuck in sharper image wine opener
The black plastic ring is secured on the clear tube that you can see the corkscrew through with four little plastic snap tabs. I used a pair of channel locks to gently pull the ring off those tabs. Once you do that you have access to the inside of the clear tube and can reverse the corkscrew and get your broken cork out. Blow debris out and reassemble. Good as new! Even if you break one tab it should still hold, and if you break multiples use some super glue to hold it in place, that will be your last chance to fix it, but at least you've doubled the life of your toy. Good luck!
Aug 05, 2014 | Home
Have Android, and been playing lottorace on browser , then you had trouble, now won't load and the browser is black and won't take anything
best solution try to do a battery pull.. simply pull the battery with the phone and then re-insert and try it.
Mar 31, 2013 | Cell Phones
Hi I have just bumped my 54 reg fiat punto sporting and now it won't start can any one tel me were the fuel cut off switch is please
not sure on that one or if it even has one,but if it does it could be inside your glove compartment or in your trunk under a plastic flap on driver side,you may have to pull the carpet on that side or cover away to find the plastic cover that goes over it,if it has one
Jan 16, 2013 | Cars & Trucks
Waring wine opener wont pull out cork
We learned that NONE of these electric wine openers like the new "plastic" corks. Take a needle nosed plyers and hold the cork tightly(as it sits inside the housing) and gently push the button to release the cork. it should work.
Apr 14, 2012 | Sunbeam Kitchen Appliances - Others
Back seats won't fold down 97 toyota camry
The plastic pull on the top of the seat may have been screwed down too much. If that happens, it will not allowing the lock mechanism to fully unlock. Unscrew the top plastic pull a little at a time and at the same time reach around and pull the lock leaver up until it is in the full unlock position. You should then be able to pull the plastic lever up normally and fold down the seat.
Nov 08, 2011 | 1997 Toyota Camry
Clutch pedal goes strait to the floor??clutch won't bleed up??
It has air bubbles on the piping, fill the deposit with brake solution, and push and pull the clutch pedal with your hand it doesn't matter if it goes straight to the floor if that happens pull it with your hand, repeat that as if you are bleeding it up, then disconnect the piping beneath the car, the air bubbles will be forced out, then reconnect the piping and repeat the procedure, push and pull the clutch pedal like a 100 times, then disconnect the piping and reconnect. The clutch pedal should be able to go back when there is no air on the piping. If that doesn't work, replace your clutch pump
Jun 23, 2011 | Honda CR-V Cars & Trucks
Yz 125 2001 stays in gear when clutch pulled in
Lose the Honda transmission oil. It may have swollen the cork on the friction plates. Go with 10w40 in the gearbox. Any major brand; Mobil, Shell, Quaker State, Pennzoil, etc.. Try the new oil and give the cork a week to shrink back down > if they will. You may need to put in a new set of plates.
Apr 17, 2009 | 2003 Yamaha YZ 125
Waring Pro WO50 Cordless Wine Opener Logo
971 people viewed this question
Top Waring Home Experts
john h
Tom Chichester
Are you a Waring Home Expert? Answer questions, earn points and help others
