Question about Dewalt 7.2-18.0 Volt One Hour Charger
Need a circuit diagram of a dewalt charger DE9108-xe 7.2V-18V one hour charger type 1:Q 96307-12/15 OUTPUT : 2.6A 7.2-18.0V 46.8VA
If I cannot have wiring diagram then can someone tell me there are 2 resistors{3 watts}in series just after the bridge rectifier & near a large electrolytic capacitor reading 400V-47micro farad & because of the heat generated within these resistors I cannot read the colour code on them they are still working one reads 10.2k ohms & the other reads 11k ohms so would they be 10k,11k or even 12k resistors thxs
Posted by johniasiello on
W.L.
  • 2,509 Answers
Can you (carefully!) measure the volts across them with a load (battery) and then the current through them by disconnecting one end, and if the charger is still working OK then they are V/I ohms, choose nearest value. 10k sounds very high, are you sure they aren't 1 ohm or less?
Posted on May 21, 2014
Wiring diagram charger
Request a wiring diagram directly from DeWalt.
Sep 28, 2017 | Dewalt Drills
Is the Dewalt DE9108 battery charger suitable for charging Ni-Mh batteries?
Dewalt DCB105 li-ion XR Battery Charger 10.8V - 20V
For Battery Type: Ni-Cd Ni-MH
Input Voltage: 110V-240V
Smart Charger for Dewalt 10.8V ~ 20V Li-ion Battery
For Brand: DEWALT
Color: Black
Brand New: A brand-new, unused, unopened, undamaged item in its original packaging
http://www.drillbattery.com.au/charger/dewalt-DCB105-charger.html
May 04, 2015 | Dewalt Drills
I have 32 dewalt 18v dc9096 batteries and 1d dewalt 18v dc9099 battery. I tried charging them and back to back they all start off charging fine then charging light speeds up as to suggest their all bad. ...
May read instructions and see if charger is compatible of charging the two types of batteries you are charging ,,,,I have 32 dewalt 18v dc9096 batteries and 1d dewalt 18v dc9099 battery
Sep 27, 2017 | Drills
Dewalt 18v drill dc988 type requires switch
Here is a link for a parts diagram for your model. It has the proper part number that you will need.
Hope this helps.
http://www.toolpartsdirect.com/cgi-bin/schematic.cgi/dewalt/DC988KA_TYPE_1
Sep 07, 2009 | Dewalt DC988kar XRP 3 - speed 1/2" 18v...
I want a black&decked battery charger part no 763883-00 for a cordless drill no cd 18c-xe
the charger its self are expensive.better to purchase new unit for a couple dollars more & u have 2 spare battery & charger
Apr 25, 2008 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
18v. charger (dewalt)
I did a little hunting and it seems you really want to use your 110v charger on a 230v supply.....
So you could use a transformer (LINK)
or you could get a local power supply pack.
Read the label on back of power pack that attach's to wall socket and charger base, see what input it can handle, some gear can handle like 110v-230v, others cant ie will read 120v
Any adaptor that puts out the same output as the original would work ie 18v DC 2.5 amps is your specs i beleive so use a transformer or another suitable adaptor
Please check my quoted specs are the same as listed on power pack of your charge ie I am assuming you are using your 110v A.C. to 18v 2.5amp D.C power pack
Jan 30, 2008 | Dewalt 7.2-18.0 Volt One Hour Charger
Dewalt 7.2-18.0 Volt One Hour Charger Logo
610 people viewed this question
Top Dewalt Drills Experts
Marvin
Marvin
efs_perpends
efs_perpends
Mike
Are you a Dewalt Drill Expert? Answer questions, earn points and help others
