Drive motor problem
LOCK ALM signal remains high for 1 s, 1
s after the drive motor has turned on.
Poor contact in the
main motor connector
terminals.
Reinsert the connector. Also check for continuity
within the connector cable. If none,
remedy or replace the cable.
Defective drive
motor rotation control
circuit.
Replace the drive motor.
Defective drive
transmission system.
Check if the rollers and gears rotate
smoothly. If not, grease the bushings and
gears. Check for broken gears and replace if
any.
Hi,you can unlock your mobile by unlock codes..the safe and best way of unlocking is by unlock codes and my personal request is that don't go for software unlocking because sometimes the software might get corrupted and may your data will be lost due to that,its my bad experience so I went for unlocking by codes from hereUnlockGenie.comand unlocked.you can too try but see to that whether your country and provider is listed..because for some service only codes are available..check with that and if your country's provider is listed then get codes and unlock your blackberry..before unlocking your mobile you can get clear instructions about how to unlock your mobile for that you can visitUnlockGenie.comto get step by step instructions..
