LG 42LG50 42 in. LCD HDTV Logo
j
john banks Posted on May 21, 2014
How do you play a sd card on panasonic thp54s10a
How do you play a sd card on a panasonic thp54s10a
vruggio
Level 1:
New Friend:
  • Contributor 35 Answers
  • Posted on May 23, 2014
vruggio
Contributor
Level 1:
New Friend:
Answers
35
Questions
0
Helped
23648
Points
87
If your device has an sd card slot & your sd card is working properly.
1st try turning the TV off
Then insert the sd card
then turn the TV on
If the tv does not begin reading the card then
Using the remote for the TV click "Source"
then scan down until you can highlight the sd as your source
then press enter.
If there are folders you must click them until you find what you are trying to play...good luck!
Brent Lavallee
Level 1:
New Friend:
  • Contributor 4 Answers
  • Posted on May 21, 2014
Brent Lavallee
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
503
Points
8
I have a Panasonic AG-HMC155 camera and I need help extracting a timestamp from a recorded video
If you copy the data from the SD card to your computer using a USB card reader, that might possibly do the trick.
tip
MOD Files on Mac OS, How to Play Camcorder MOD Files on Mac
Similar to TOD, MOD is a kind of recording format being used in digital tapeless camcorder like JVC, Panasonic, Canon. MOD video format is comparable to XDCAM EX, HDV and AVCHD.
MOD is used exclusively for standard definition video files, while TOD is used for high definition files. Both MOD and TOD are file-based formats that are stored on a random-access media. Directory structure and naming convention are identical except for extensions of media files. Standard definition video is stored in MPEG program stream container files with MOD extension; in most other systems these files have extension MPG or MPEG.
The following list is about JVC, Panasonic, and Canon MOD camcorders.
JVC MOD camcorders
* 2004: GZ-MC100 (SD), GZ-MC200 (SD)
* 2005: GZ-MG30 (HDD), GZ-MG70 (HDD)
* 2006: GZ-MG37 (HDD), GZ-MG77 (HDD), GZ-MG505 (HDD, SD/SDHC card)
* 2007: GZ-MG130 (HDD), GZ-MG155 (HDD), GZ-MG255 (HDD), GZ-MG555 (HDD, SD/SDHC card)
* 2008: GZ-MS100U (SD/SDHC card)
* 2008: GZ-MG7230 (30 GB HDD, MicroSD)
* 2009: GZ-MG630 (60 GB HDD, MicroSD), GZ-MG670 (80 GB HDD, MicroSD), GZ-MG680 (120 GB HDD, MicroSD)
Panasonic MOD camcorders
* 2003: SV-AV100 (SD card)
* 2005: SDR-S100 (SD card)
* 2006: SDR-S150 (SD/SDHC card)
* 2007: SDR-S10 (SD/SDHC card), SDR-H18 (HDD, SD card), SDR-H200 (HDD, SD/SDHC card)
* 2008: SDR-H20 (HDD, SD/SDHC card), SDR-H60 (HDD, SD/SDHC card)
* 2008: SDR-S7 (SD/SDHC card)
* 2008: SDR-SW20 (SD/SDHC card)
* 2009: SDR-SW21 (SD/SDHC card)
* 2009: SDR-S26 (SD/SDHC card)
Canon MOD Camcorders
* 2008: FS100 (SDHC), FS10 (SDHC), FS11 (SDHC)
* 2009: FS200 (SDHC), FS21 (SDHC), FS22 (SDHC)
For Mac users, when they want to watch MOD files shot by JVC, Panasonic, Canon camcorder with iPad, iPhones, iPods, in Quicktime, in iMovie, in iTunes, or on PCs, etc. They may be annoyed that how to upload MOD files to Mac and play MOD video on Mac OS.
Now, there are tutorial and guide for you below will help you solve these problems.
1. Connect your JVC, Panansonic, or Canon camcorder to your Macs or PCs with cable USB or Wifi.
2. Turn on your camera and select the mode of camcorder like PC mode. iMovie on Mac will open automatically the Import Window.
3. You can review your video or select "Import All"and select your JVC, Panasonic, or Canon camcorder on the computer screen and click "OK."
4. All camcorder MOD videos will have the file extension "MOD" Once the backup is complete, then close the program.
After uploading your camcorder MOD files to your PC or Mac, you can use
a MOD Video Converter for Mac to convert MOD files to Mac firstly, and then you can play JVC, Panasonic, or Canon MOD files on Mac. More information about how to convert MOD files on Mac and edit MOD files on MacOS you can click here.
on Sep 13, 2010 • Computers & Internet
tip
How to Upload/Put and Play JVC, Panasonic, Canon Camcorder MOD Files on Mac
JVC MOD camcorders
After uploading your camcorder MOD files to your PC or Mac, you can use a MOD Video Converter for Mac to convert MOD files to Mac firstly, and then you can play JVC, Panasonic, or Canon MOD files on Mac. More information about how to convert MOD files on Mac and edit MOD files on MacOS you can click here.
on Aug 12, 2010 • Computers & Internet
3helpful
2answers
How do I format the SD card on the lumix DMC-TZ30
Go to the camera's Menu setting and select format memory card.
1helpful
My viera tv will not play any movies! I have converted movies to both mpeg2 and avchd formats, put them on my sd card, and the tv will not play them!
Panasonic requires a very strict AVCHD structure from a camcorder that nobody has been able to figure out yet.
http://www.dvinfo.net/forum/avchd-format-discussion/99716-avchd-play-panasonic-sd-card-slot.html
Seems like the Viera is fussy about video encoding.
It goes to a black screen with a yellow sign with a arrow on it pointing down, it also has a green, yellow, and red bar at the bottom.it stops at the red.
Had this same issue. Your probably trying to play either Crank2 or StarWars. Talked to Panasonic Tech Support and they said not enough memory to play disc and gave me these instructions:
"This movie title requires that an SD card of 128MB or larger to be inserted into the BluRay player prior to inserting the BD disc each time you watch this movie.
The SD card must be formatted in the BlRay player before use. (Do not format the SD card on your PC)
Formatting an SD card in the player:
-Insert an SD card (1GB or higher) into the SD slot of your BluRay
-Press [FUNCTIONS], select "other Functions" and press [OK]
-Select "Card Management" and press [OK], then follow the on-screen commands
Once formatting is complete, leave the SD card in the SD card slot. Insert the movie disc into the BluRay player and it should play normally."
Personal note, the bar graph that has always stopped at the red will hesitate for quite a while and then the rest of the bar will fill up and BD will begin to play.
10helpful
2answers
Panasonic CN-NVD905U SD Card map update download
I bought the map update from Panasonic for $150, even tho it was advertised for $300. I called to order it, and it came with a disk and SD Card.
1helpful
SD card unreadable
does card have notch / ...switch.... on side that needs slid to other position to be read?
Grand Canyon Tech
Grand Canyon Tech
Kolbrun...
