Kodak EasyShare C360 Digital Camera Logo
Question about Kodak EasyShare C360 Digital Camera
Where is the capacitor for time and date saving in the dx7440 kodak camera
3 Related Answers
Anonymous
SOURCE: Kodak z1275 easy share camera
never use kodak again!!!
Posted on Dec 17, 2008
Anonymous
  • 6831 Answers
SOURCE: I broke my Kodak EasyShare
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance. Also, please be so kind to let me know if you found this helpful.
Regards
Andrea
Posted on Nov 09, 2010
Anonymous
SOURCE: How do I format a
Go to Format by pressing the MENU button on your camera. You will see several options, one being 'Memory Card'. Press this, using your central button (on dial) and note that it will delete anything you may already have on the card ie if you used it for something other than the camera.
Posted on Jan 25, 2011
Difficulty formatting new memory card for a Kodak Easy Share DX7440
The DX7440 works with MMC and SD cards, which max out at 2GB. While your 4GB SDHC card fits into the slot, it is electronically incompatible and will not work with this camera. You need to stay with SD cards, 2GB and smaller.
2helpful
Lexar 4 GB SDHC memory card formatting for my DX7440 camera
The DX7440 works with MMC and SD cards. While SD cards fit into the slot, they are electronically incompatible and will not work. You need to use cards 2GB and smaller.
2helpful
I HAVE A KODAK DX7440 JUST BOUGHT 8 GB MEMRY CARD HC,WHEN I PUT IT IN THE CAMERA IT DOESNT FORMAT TRIED MANY TIMES
The DX7440 works with MMC and SD cards. Your 8GB card is actually an SDHC card. While it fits into the slot, it is electronically incompatible and will not work in the camera. You need to use MMC or SD cards, 2GB and smaller.
How do I format a memory card in this DX7440 kodak camera?
Is the kodak dx7440 compatible with the sdhc cards?
Hi. Kodak DX7440 is using standard SD card or MMC card up to 1GB (some says it will read 2 to 4GB standard SD but I haven't tried). SDHC is high capacity, 4GB above and will not work on your camera.
Looking for replacement plug for the k7440 charger
KODAK no longer produces DX7440 cameras and acc.
You might be able to find it second hand from Ebay or other online forums/websites.
Good luck
1helpful
Lost articles that came with DX7440. Includes
Please follow this link in order to retrieve the manual:
http://www.kodak.com/global/plugins/acrobat/en/service/manuals/urg00261/DX7440_GLB_en.pdf
The accessories are no longer produced and sold through KODAK.
You might be able to find them on E-Bay.
Good luck.
Picture file size too big when loaded into easyshare software
Upgrade you computer.
You could also lower the quality of the pics on the camera.
Menu, Camera Settings. Pixel Quality.
DX7440 kodak cameras plastic battery lock broke off
I also have the same problem but it never worried me as when you close the outside battery lid it keeps the battery in place ok . I have a problem with the joystic operation on my dx7440 if any body has any suggestions
Top Kodak Cameras Experts
David Shaub
Marvin
Marvin
Are you a Kodak Camera Expert? Answer questions, earn points and help others
