Question about Pride Go-Go Ultra X 4-Wheel
Intermittent fault causes scooter to stop after about 1.5 miles. waiting for a few minutes all is well again. The battery is fully charged but when the scooter stops it shows on the indicator as flat. /then after a wait the indicator goes back to showing the battery is fully charged
The motor is overheating. The service manual will tell you how to test. Pride has a service manual you can download from their website.
Posted on Feb 24, 2015
SOURCE: I have a pride victory xl8. Problem - was running
All scooters have a protection system built in to prevent burning up the motor, and the user, should the scooter overheat. It sounds like yours overheated. If the temp. outside was warm to hot, and your weight is near the weight limit for the scooter, and you are taxing the motors over a hill, or unstable terrain, then the scooter goes into "limp home mode", or just enough to get you a bit aways, and then it will turn off. After a few minutes to cool off, it will go again, but shut down fairly quickly because it takes a spell to let the whole transaxle-motor assembly to get cool.
Check your weight, and anything else you may be carrying with you on the scooter. Check the terrain, and incline you are going against. Throttle down for all these occassions. If you overloaded the system at some point, then you may have overheated the brushes. Remove them (2) with a standard screwdriver and see if the copper coil is still flexible and springy. If not, replace it/them.
The damage may already be done, so it may need a new motor/transaxle assembly. An expensive proposition I'm afraid.
Posted on Jul 09, 2009
SOURCE: Same problem
If your batteries have ever gone dead, they can show fully charged, then completly discharge very rapidly. Take them to autozone and ask for a "load test". If they don't hold a load, replacement is nessary. [email protected] for more if the batteries pass load test
Posted on Oct 24, 2009
Testimonial: "It was the batteries - they needed replacement. Thanks to all who responded!"
SOURCE: battery charger indicating that batteries
With a Pride Scooter the charger will turn green if its fully charged and if there is a bad connection in the wiring with the batteries. If you plug in the charger and the light comes on green right away then there is a problem with the wiring or connections. Take a voltmeter and read the voltage at each battery. Fully charged they should be 13-15 volts each. If they are less than 12 volts then they are not charged and the charger is not working correctly. If the batteries are really low like less than 8 volts each then the scooter might not come on at all. If you find that the batteries have at least 12 volts or more then there is a wiring problem from the rear of the scooter to the front tiller. Pride has a habit of developing problems in the harness running from the rear to the tiller. My suggestion is to contact your provider (where you got the scooter) and have them troubleshoot the scooter. If the scooter is less than a year old then it should be under warranty and your provider will have to fix it under warranty. Sorry I don't have a quick fix for you but scooters are notoriously bad to troubleshoot and repair, especially long distance. Hope this helps you
Posted on Mar 15, 2011
SOURCE: The batteries we put in
The charger from you have indicated is faulty not working properly the needle should not be going back and forth but once in the charging mode should be stable reading and drawing down to 0 slowly as the charge is taking place on the batteries you may wish to replace the on-board charger. In the meantime you can use a trickle charger at home from the wall.
Or a battery charger make sure that it is set to the lowest charge point 6 volts. This will do the same thing as an on-board charger for the scooter. Until you replace the faulty one on the scooter. I would also bring it in and have it checked out as well for a second opinion. They can do a quick test on the unit and maybe it is a simple part replacement and not the whole unit this is how I would deal with it. Thanks for using FixYa! John
Posted on Apr 14, 2011
SOURCE: I have a pride gogo
Regards,
Tony
Posted on Jun 16, 2011
Mar 16, 2016 | Honda Cars & Trucks
Apr 14, 2017 | Cars & Trucks
Sep 03, 2017 | Jeep Grand Cherokee Cars & Trucks
Aug 05, 2010 | Philips Lands Phones
May 12, 2010 | Hartford VR 200X Motorcycles
May 02, 2010 | Electric Mobility Mobility Electric Power...
Mar 02, 2010 | Pride Legend XL Heavy-Duty 4 Wheel Scooter...
Jun 01, 2009 | 2006 Audi 5000
Jan 25, 2009 | 1998 Chevrolet Lumina
Jan 20, 2008 | Sharp 13VT-R100 13 in. TV/VCR Combo
196 people viewed this question
