Question about Husqvarna Designer I
My designer diamond gives me a message that machine needs to rest ,but I have not used it in over 24 hours. I press the ok button but it continues to give me the same message.
deborahcha
    Novelist:
  • Husqvarna Expert
  • 371 Answers
It is either the motor that needs replacing or the power supply. I've seen both. There is an updated power supply that was recently recommended by Viking. These parts should still be covered by the Manufacturer Warranty (provided you are the original owner and purchased from an Authorized Viking Dealer). Take the machine to an Authorized Viking Dealer. If it is still warranty, you should only be charged for the service/labor for the repair. You can find a local dealer by checking the Viking website athttp://www.husqvarnaviking.com/us and going to the Locate a Dealer link.
Good luck. I know how frustrating this can be.
Posted on Jul 13, 2014
3 Related Answers
Anonymous
SOURCE: Have 3D software,Pfaff 2140 machine and Hus Designer Diamond mach
I have loaded the 4D software and have communication with my Husquvarna machine through that. I communicate with my Pfaff through the old 3D software on my computer.
Posted on Nov 24, 2008
Anonymous
SOURCE: Husqvarna Diamond Embroidery unit problems
Make sure that the red disk (smaller than a floppy) on the underside of your embroidery unit has been removed. Remove and discard the red disk. It is used for shipping purposes only. Joyce
Posted on Jan 10, 2009
Stefania Mason
  • 5 Answers
SOURCE: My designer diamond keeps giving me a message that
i got the same problem with my new pfaff & try to arrange to send back to shop as i never use it
Posted on Mar 08, 2010
Machine needs to rest message
When you see this message, wait until the OK message is enabled. Tap the OK button and then resume sewing. This message occurs often enough to be listed in the manual under Pop-up messages in both the Sewing and Embroidery section. (That starts on the last few pages of each of these "chapters".) Turning off the machine while this message is displayed may cause on issue with the on-board computer.
For the Husqvarna Viking Designer Diamond Royale, you can find the manual on the product page: http://www.husqvarnaviking.com/en-US/Machines/DESIGNER-DIAMOND-Royale . The direct link to the manual is http://www.husqvarnaviking.com/getattachment/Machines/DESIGNER-DIAMOND-Royale/Designer_Diamond_Royale_manual_ENG.pdf.aspx . The pop-up for the Machine needs to rest is shown on pages 4-26 and 8-14 (pages 74 and 123 of the PDF). The Designer Ruby Royale has the messages on pages 4-24 and 8-14 (70 and 116 of the PDF). The manual for this machine is here: http://www.husqvarnaviking.com/SiteMedia/Products/Machines/-%20DESIGNER%20RUBY%20Royale/Manual/Ruby_Royale-manual-EN.pdf .
I hope this helps. If the message comes up after a few minutes of sewing (under 5), I would recommend that you consider cleaning the bobbin area. Sometimes a flossing swab can help remove debris that has gotten into the corners below the bobbin. If that doesn't help, your machine may need to be serviced.
Nov 22, 2017 | Husqvarna Sewing Machines
Will not sew continuestly when im embrodering when i press the reverse button
It is completely normal for a Bernina 180 and other Bernina models to stitch just a few stitches and stop after first pushing the reversing button. The reason for this is so you can cut off the extra piece of top thread so it does not get caught up in the embroidery design. After you cut off that extra piece of thread, press the reversing button (hold it in till the machine starts) then it will continue with the design. Assuming you do not have a problem (a message would come up on the screen) or you are out of bobbin thread, the machine will continue to embroider till either the design is finished or it stops because you need to change the upper thread to the next color. Each time you start to embroider it will stitch about 3 or so stitched and stop. Cut off the extra thread and press the reversing button again to continue.
If this is not the problem you are having then you need to describe your problem better, in more detail.
This should help! Bill
May 26, 2015 | Bernina Artista 180
I have a Husqvarna Viking Diamond Deluxe and I am getting the following Pop Up Error Message. "Machine needs to rest. Wait a moment and touch OK icon when it is enabled. I have done this a numnber of...
This is usually a bad transformer. If the machine is less than 5 yrs. old it is covered under the mfg. warranty. You need to take it to an authorized dealer.
sorry!
Feb 23, 2015 | Husqvarna Sewing Machines
It is either the motor that needs replacing or the power supply. I've seen both. There is an updated power supply that was recently recommended by Viking. These parts should still be covered by the Manufacturer Warranty (provided you are the original owner and purchased from an Authorized Viking Dealer). Take the machine to an Authorized Viking Dealer. If it is still warranty, you should only be charged for the service/labor for the repair. You can find a local dealer by checking the Viking website at http://www.husqvarnaviking.com/us and going to the Locate a Dealer link.
May 20, 2014 | Husqvarna Designer I
Remove thread message in husqvarna viking sapphire 870 quilt
I had this same problem, on my Designer Diamond. I blew it out with an air can and that didn't work, but then I decided to turn it off, then back on and start sewing a line in reverse. That seemed to fix it. My machine is working fine now.
May 29, 2010 | Husqvarna Sewing Machines
Jan 10, 2009 | Husqvarna Viking 1
Nov 23, 2008 | Husqvarna Designer I
PED basic card
I haven't got the 600 buyt I do have a Bernette Deco and when I save designs on my USB stick I have to ensure they are saved to a particular folder in the stick. Perhaps there is a similar type of requirement?
Apr 07, 2008 | Bernina Bernette Deco 600
Sewing Machines Logo
418 people viewed this question
Top Husqvarna Sewing Machines Experts
sewcrazyshan
Level 1 Expert
Susan Null Spradlin
Level 1 Expert
Irene Tulloch
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
