Question about Casio FX9750GII Graphic Calculator
How to do sum of a sequence - Casio FX9750GII Graphic Calculator
Sigma notation on fx9750gii
The syntax is
Sigma ( function (n),index n, starting value of index n, ending value of index n, increment of n).
If you omit the increment of the index the calculator will assume it is equal to 1
Dec 02, 2012 | Casio FX9750GII Graphic Calculator
Alpha key not recognized when pushed
When the ALPHA key is pushed the cursor shows an A. Press one of the keys that has the same color as the ALPHA key (A,B,C,...X,Y,Z).
If you have the MathPrint OS, the ALPHA F1/F2/F3/F4 sequence activates shortcuts to newe features (fractions, logab, sums etc..)
Sep 16, 2011 | Texas Instruments TI-84 Plus Calculator
Have an Abit A17 motherboard that stops booting with a check sum error. Code on the digital readout is either IA or 1A, neither of which is in the manual. Any idea about this?
Press delete as the system boots up and go into BIOS Setup.
Change boot sequence so that your machine starts with the CD/DVD ROM disk.
Boot from the CD/DVD and do a clean installation.
Jul 15, 2011 | Abit AI7 Motherboard
I want to formate laptop but sum surcomstances would be create when i click reboot but after some minuts so blu page and then after start xp but not start operating system
You need to set up in the bios how the laptop must boot. Try pressing F2 or DEL on boot to get into the bios. Find boot sequence and set cdrom first boot
Jan 15, 2011 | Computers & Internet
My daughter's homework is the for the sequence below is add * 2.4 ____ ____ ____ 17.2 can anyone help?
I'd guess there should be some more information... for all we know, you might be requested to add 3.7 to each number, so that you get 2.4, 6.1, 9.8, 13.5 and finally 17.2 . (You get 3.7 by subtracting the first number from the last, and dividing by the number of sums - which is the number of blanks plus one).
This is the simplest linear sequence, but in truth, it could be anything.
Let me know, especially if you gather any additional information.
Mar 15, 2010 | Mathsoft StudyWorks! Middle School Deluxe...
Operating system not found dont have a recoverry cd
do you have any external harddrives or flash drives plugged in? iv found that can sumtimes confuse sum systems?
May 18, 2009 | E-Machines eMachines Desktop PC
The number e
e to the first power is 2.71...
Press the following buttons in sequence: 1, 2nd, LN, + and then your numbers.
Jul 31, 2008 | Texas Instruments TI-30XA Calculator
Read n & m, display the sum of all the even and odd numbers between n to m.
#include <stdio.h>
int main()
int n1, n2, i;
int sum = 0;
n1 = 3;
n2 = 11;
for (i = n1; i <= n2; i++) {
if (i % 2 == 0) {
printf("Adding %d\n", i);
sum = sum + i;
printf("sum = %d\n", sum);
return 0;
Feb 21, 2008 | Computers & Internet
START PROBLEM
U2 Counter sum check error When the counter check sum value stored in the EEPROM is abnormal
Enter sequence...clear, interrupt, 0, interrupt. The copier will go off. While off enter 16 and Start. Your copier will come back on. press Clear All.
may need a new cartridge as chip may be broken if this does not work
Aug 29, 2007 | Sharp AR-5316 Advanced Digital Imager...
Casio FX9750GII Graphic Calculator Logo
35 people viewed this question
Top Casio Office Equipment & Supplies Experts
Ekse
Colin Stickland
Colin Stickland
jasbo
jasbo
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
