The "unlock" feature is no longer available to accept a fingerprint or a passwordThe "unlock" feature is no longer available to accept a fingerprint or a password
You can't post conmments that contain an email address.
The driver could be out of date. Try opening device manager. If you are running Windows 7 or Vista, click on the start menu and type device manager. If you are running Windows XP, click on start, control panel, system, then the hardware tab, and device manager. Scroll down and open the plus' until you find the fingerprint reader. When you find it, right click on it and click update driver. Tell it yes, you want it to search online for a new driver.
Hi, You didn't mention if the dvd was working before or it's new.
Now, you have 2 options to try: 1) Try to open the same DVD on other DVD-Reader. If it was read, then the dvd is unreadable on your laptop, because it's bad, or the DVD-Reader have problems, OR
2) Try other DVD on your laptop, if it was read, then your DVD-Reader can't read all types of DVDs, if not, then the dvd is bad Tell Us your results, please Good Luck
If its more than 8GB it wont work. If its less than 8gb then put it into card reader on your computer and reformat the card. If that doesnt help or you computer doesnt recognize it either obviously the card is bad.
bought a hamster fingerprint scanner, i installed it and it scanned
offline but it couldn\'t connect with the website i want to use it with,
all it shows is no scanner connected
dentifying the fingerprint readerA fingerprint reader provides extra security for the PC. The VeriSoft Access Manager by Bioscrypt uses the fingerprint reader to identify the user, and controls access to Windows or other secure systems. Instead of typing a User ID and password, you can move your finger across a sensor to logon or start commonly used applications. Verisoft Access Manager can manage all of your different secure accounts and the required user names and passwords by recognizing your fingerprint.On HP notebook PCs, the fingerprint reader is a small metallic sensor located near the keyboard or display. By swiping your finger perpendicular to the metallic sensor you can logon to the PC, a network, or open a program.
Before you can use the fingerprint reader, you must set up the fingerprint reader by registering your fingerprint with the Access Manager.
Set up the fingerprint reader
To set up the fingerprint reader to recognize a user, the user must have a logon account on the PC and the account must have a password. Multiple users can be registered for the fingerprint reader if each has their own user account.
In Windows, double-click the VeriSoft Access Manager icon in the notification area of the taskbar to open the My Identity window.
Alternately, click Start > All programs > Verisoft > My Identity .
Click Log On to open the VeriSoft Logon Wizard. Click Next to begin.
Enter the User's Windows password in the Password field on the Introduce Yourself page, and click Next .
If you have successfully logged on to Windows, click Finish to close the wizard.
Click Register Fingerprints on the My Identity window, to open the VeriSoft Logon Wizard. Click Next to begin.
Select a finger shown on the hand graphic, and then slowly swipe your finger across the sensor. One of the squares below the hand graphic will change color when the scan is accepted. A message displays if the scan is not accepted.
Swipe the same finger across the sensor again until all four squares change color, then clickNext to register the finger print.
If you need to start over during the fingerprint registration process, right-click the highlighted finger on the screen and then click Start Over .
If prompted to register a second fingerprint, click a different finger on the hand graphic, and then repeat steps 5 and 6.
After using the Registration Wizard to registered at least 2 fingers, click Finish .
To set up the fingerprint reader for a different Windows user, log on to Windows as that user and then repeat steps 1 through 8.
After registering your fingerprint you can log off and then use your registered fingers to log on to Windows.
Using Fingerprint reader before registeringIf you swipe your finger across the fingerprint reader before it is set up, the Access Manager opens a logon wizard window and prompts you for informa
I installed GrFinger SDK 4.2. that contain FingerCap USB Driver 1.0 but through reading on internet I learned that this version contain many problems , so I when replace it with Fingerprint_SDK_2007 that contain FingerCap USB Driver 1.2 ,Thank God ,my problem have been solved
Thank you
ok.. please update your related drivers firstly.. but the actual trick is to go
Manage add-ons, and find your related add-on for Explorer (DigitalP in my case on my HP Laptop) and ENABLE it..
also right click My computer on your desktop, then click Manage,
then find and load Biomethric Authentication Service, under services.. (DPHost in my case)
i am almost positive in most cases, enabling your digital finger print reader on MANAGE ADD-ONs secction must help..
