SOURCE: Water heats but does not come out reservoir
could be calc deposit buildup from water had the same problem a while back buildup was inside the tubes and turned almost into rock inside it if thats the case junk it and buy another coffee pot just my sugestion if not you can try C.L.R ( calc lime and rust remover) but make sure you rune water through the pot several times before you use it again after you use clr.
SOURCE: will not purculate the coffee, heats but will not
Hi, if it is heating up but not perking it is the main heating element, You can get one at repairshack.com
