Question about Electrolux Frigidaire Professional Series 24 in. Built-In Dishwasher Dishwasher
What additional parts may fix error code 11 on electrolux EDW7505HPS0A
Error code 11 valve light showing on control board. replaced Drain pump & valve. what else may cause time out ?
Electrolux
  • Official Brand Answer
  • 4,342 Answers
Good Afternoon Friend, thank you for your post!
If you are receiving an error code E11 on your Electrolux dishwasher (EDW7505HPS0A), it usually means that you are experiencing a problem with the drain valve. If you have already replaced the vale and pump, at this point, I would recommend reaching out to a professional or alternatively, visit the manufacturer website for a comprehensive listing of appliance techs in your area that can ensure the wiring between the main control and the drain valve was correctly installed. Best regards! - Z
Posted on May 27, 2014
1 Related Answer
Daniel S
Daniel Scott
  • 4323 Answers
SOURCE: I have an Electrolux EIDW
Hi
The issue is either with the wash pump that is going bad or the motor itself that is unable to run. As the washer fills and then drains immediately so the pressure/float switch should also be checked. Hope this helps...please post back for further assistance.
Daniel
Posted on Jan 16, 2011
Electrolux EIDW6305GS1 will not run , keeps flashing error code 11 which indicates drain valve problem. I have replaced drain valve, wash pump, float valve and reed switch but no luck, still flashin
Hello Gene Skates - Typically error code E11 indications that there is an issue with the drain valve, possibly the main control board is timing out before receiving status of drain valve. This is typically not a DIY job and strongly recommend contacting a professional to check the wiring between the main control board and drain valve since you have already replaced the drain valve.
Jan 11, 2013 | Electrolux Frigidaire Professional Series...
Electrolux dishwasher with error code 11
Hello Jason Johnson - Typically error code E11 indications that there is an issue with the drain valve, possibly the main control board is timing out before receiving status of drain valve. I strongly recommend contacting a professional to check the wiring between the main control board and drain valve.
Dec 30, 2012 | Electrolux Frigidaire Professional Series...
Error code 11 on electrolux wave dishwasher
Hello - Typically error code E11 indications that there is an issue with the drain valve, possibly the main control board is timing out before receiving status of drain valve. I strongly recommend contacting the technician that repaired your unit previously to check the wiring between the main control board and drain valve. Some certified technicians warranty their labor and part for 30 days.
Nov 04, 2012 | Washing Machines
E11 code on electrolux dishwasher
You are experiencing a drain valve issue - Main Control Board timed out before receiving status of drain valve. Check wiring between Main Control Board and drain valve. If correct, replace drain valve. If error still exist, replace Main Control Board.
Aug 16, 2012 | Electrolux Dishwashers
Electrolux dishwasher error code 11
You are experiencing a drain valve issue. Main Control Board timedout before receiving status of drain valve. Check wiring between Main ControlBoard and drain valve. If correct, replace drain valve. If error still exist,replace Main Control Board.
Jul 21, 2012 | Electrolux Dishwashers
How do i reset an electrolux 1080
E20 is an error code for a drain pump issue. The error will reset itself if the issue has been resolved. If it or another code continued to appear, then the unit has not been accurately fixed.
Jul 19, 2012 | Electrolux EIFLW55HIW Front Load Washer...
I have an error 04 showing on my dishwasher, and the cycle will not run. Please help!
dryer damper problem. there is another post that will help from electrolux personnel.
Thank you in advance for allowing Electrolux to assist you in
this matter.
I apologize for the inconvenience and concerns this dishwasher unit has been causing you. Unfortunately the error "E04" code does indicate an issue with the drying damper. Now this is something that a technician would have to assess because wiring is needed to be checked.
Check wiring between Main Control Board and upper fan. If correct, replace upper fan.
If your unit is brand new it is covered under warranty and you can choose to contact your dealer for a repair technician, or visit www.electroluxappliances.com/servicelocator to find a listing in your area.
Kindest Regards,
Chris Polk
Online Outreach Representative
Electrolux Major Appliances
Er 01
Leak Detector - When water is detected under
the tub.
Er 02
Thermistor - When thermistor/turbidity module
fails
Er 03
Wash Pump - Wash pump not operating
Er 04
Drying Damper - Drying damper not operating
Er 05
Upper Fan - When in the dry cycle, the control
board does not receive proper speed feedback
from the upper fan
Er 06
Lower Fan - When in the dry cycle, the control
from the lower fan
Er 07
Drain Valve - When in the drain mode, the control
board does not receive proper position feedback
from the drain valve
Er 08
Tactile or touch switch - Control board has
verified a switch on the user interface is bad or
shorted
Er 09
Communications - Communication failure between
main user board and power supply
Er 10
Mains Relay - Failure in the mains power relay
Er 11
Drain Valve - Time out before finding a state for
the drain valve
Er 12
Drain Valve - The drain valve is running when it
should be off
Er 13
System wide - Lost control of the State Machine
Jun 23, 2011 | Electrolux Dishwashers
Washing machine error code on Frigidaire ATF6000E
I think I figured this one out. I think it means that the washer is not able to drain, therefore it won't spin either. Underneath the washer is a series of outlet hoses and within one of them is a filter. When I finally found the filter it was clogged up with lint, fibers from a pillow and coins. You have to dig the filter out and then clean the filter and rehook up the hoses, this was relatively simple even for me. The washer works perfectly now.
Mar 29, 2008 | Frigidaire ATF6000ES Front Load Washer
Electrolux Frigidaire Professional Series 24 in. Built-In Dishwasher Dishwasher Logo
539 people viewed this question
Top Electrolux Dishwashers Experts
Mike
Marvin
Marvin
Are you an Electrolux Dishwasher Expert? Answer questions, earn points and help others
