This is the most common question when computer users start to
experience this error messages pop up on their screens. Many people
immediately call in their computer-technicians to fix this problem and
end up paying huge amount of money on professional fees.
Unknowingly,
this problem could be easily fixed on your own, even if you know little
about computers; and further prevents this problem to occur in the
future. There are many ways to solve this and I shall discuss further
on these methods; as well as the ones easier for you to do.
One
of the best methods in dealing with this kind of situation is to verify
the settings of windows update. If you keep on updating your system,
some of the applications may not be compatible with your OS; hence,
this error message shows up. In some cases, you may need to register
again your update DLL file in order to fix this issues.
Another
method is to reboot your computer in order to reload your operating
system. There are times when your computer encounters problem during
startup and rebooting your system can resolve the issue. Still another
technique is to remove update files which are already corrupted; these
files are usually found on your registry. In using these methods, you
may need some expertise in order to make precise identification of
corrupted files.
The best way to solve your problem is to use
registry cleaners. This software can fix this trouble because this
problem may be related to registry issues caused by the build-up of
unwanted trash files. These junk files can cause various types of
problems in your computer including svchost.exe application errors; it
can further cause your system to run slow, takes longer time to start
up, and eventually crash if not resolved immediately.
Therefore,
the next time you encounter this message, you don't have to call in
your technician to fix the problem for you; because you already know
how to fix svchost.exe application error yourself using
registry
cleaner software.http://www.ultimatepcutilities.url-go.com
Need more details. What has happened after the error or during the error
