Question about RCA P46924 46" Rear Projection Television
SOURCE: RCA 46" Rear Projection TV-How do you adjust the convergence colors
are you looking to correct the problem or make and adjustment
adjustments you can do from the remote once you in the menu
however if that doesn't fix your problem most likely it need convergence ic's
http://www.digitalhome.ca/forum/showpost.php?p=564268&postcount=220
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Posted on Dec 05, 2007
SOURCE: RCA P46924 46 in rear projection tv will not turn on
More than likely it has bad solder connections on the circuit board. You could try tapping lightly on power supply/deflection boards to see if it makes contact. Usually I find bad solder on those right under where the power cord plugs in, on the bottom of the board. If you have a soldering iron and solder you could save a few hundred dollars in repair costs, but use caution and make sure all power to set is disconnected. Maybe mark each plug as you disconnect them. Hope this helps. Good luck, Russmann.
Posted on Jun 02, 2008
SOURCE: RCA 46 inch convergence problem
AM sorry, but can you provide your model number TV and chassis please?. I will tell you location parts. Thank you
Posted on Aug 13, 2008
SOURCE: rca projection tv is blurry
Hi, you need a tv tech, G2 focus block and pincushion circuit are what your describing, these are both related to the high voltage circuit but are 2 different circuits, definitely not a layperson repair, do yourself a favor and call a tech on this one, good luck, video-tek
Posted on Feb 05, 2009
Find a large rifle and put it out of its misery. Bowing is either from a problem in the pincushion correction circuit or the convergence circuit. Blurry picture or poor color rendition is most likely bad CRTs ( picture tubes)
michtech
Posted on Feb 13, 2009
