Question about Canon Pixma MP450 All-In-One InkJet Printer
Can't get MP Navigator to work on Vista
I downloaded a new driver from Canon and cannot get the MP Navigator to open so I can choose scanning, etc. The new computer won't accept my CD which does have old drivers for Windows XP... Help! The printer does work, just not the multitasking part.
Posted by wesearch on
  • Anonymous Dec 04, 2007
    CANON PIXMA MP450 PRINTER INSTALATION WITH WINDOW VISTA
  • Anonymous Jan 01, 2008
    Vista doesnt detect my printer
Anonymous
Finally navigated the Canon.com site and found help for Vista drivers. After 3rd attempt, everything is working. Thanks for looking at this problem. You have to install both the MP Navigator and the new drivers... nothing simple like all in one!
Posted on Nov 04, 2007
How to get scanner to attach to e mail
Operate the scanner from the computer not the printer.
Have you loaded the MP Navigator progam from the cd supplied with the printer?
If not, do that first and then follow the steps below.
Double click MP Navigator icon on desktop.
Choose "custom scan with one click "
Save to pc. (" attach to email "only works on windows mail)
Open saved location and rename.
Write your email & click on insert drop down box
Click on "pictures inline "
Open pictures.
Open MP Navigator folder
Choose scanned item by name
Click on open box
Scan will appear under the text in your email.
May 31, 2014 | Canon PIXMA MP510 All-In-One InkJet...
Menu does not appear on the panel.
When the MX300 printer driver installed, will automatically be installed Canon MP Navigator. Canon MP Navigator function to activate the scanner. Try to search for Canon MP Navigator icon, on the desktop or START menu.
If Canon MP Navigator is not installed, you can download here Canon Service & Support. Open link, then select the operating system you use, download Canon MP Navigator, then install.
Nov 28, 2011 | Canon MX300 Office All-In-One Printer
I lost my cd to my canon MX320 and cannot scan or do any of the things I use to be able before my other pc broke.I now have a windows7 laptop and would like all the ammenities that my printer does on my...
Canon has the drivers and software for supported OS versions here: http://usa.canon.com/cusa/consumer/products/printers_multifunction/office_all_in_one_inkjet_printers/pixma_mx320?selectedName=DriversAndSoftware . Select your OS in the drop-down menu. Make sure to select the x64 bit version if you have Win7 64-bit. To check this, click Start > Control Panel > System and Security > System. If the OS title ends with x64, you have the 64-bit OS. Otherwise it's the 32-bit version.
Expand the section marked software and get the MP Navigator to get the full feature set of the all-in-one. Download this file. Then disconnect data cable from the computer. Uninstall the generic driver that is currently installed. (Start > Control Panel > Devices and Printers ; right click on the MX320 and choose Remove Device) Reboot the computer if prompted to do so. Then find the MP Navigator software installer and double-left click on it. The UAC prompt will come up and you need to accept the changes (note you must be the system administrator). Then connect the USB cable when prompted to do so.
Unfortunately you will not be able to download any third-party software that came with the original CD.
I hope this helps.
Sep 13, 2011 | Canon PIXMA MX310 All-In-One Printer
Hi. I have a canon pixma mp780. I can use it to print fine with my Macbook pro (OSX), but I cannot get it to scan with either mac's image capture (can preview image but scan button is greyed out) or with...
Hello thanks for asking, i notice you you really did some valid but the problem still exist. Please check the settings for your printer to make sure they are correct, and please uninstall and reinstall the drivers for the printer once again and please make sure its the right drivers for your printer.
Jun 10, 2010 | Canon PIXMA MP780 All-In-One InkJet...
Which is the scan button mp520 canon printer
Easy Scanning with One-click You can complete from scanning to saving easily by simply clicking the corresponding icon.
1. Place the document face-down on the platen.
2. On the Windows desktop, double-click (MP Navigator EX 1.0).
Alternatively, on the Windows taskbar, click Start, point to (All) Programs, Canon Utilities, then MP Navigator EX 1.0. Then click MP Navigator EX 1.0.
The MP Navigator EX navigation mode screen or one-click mode screen opens.
3. Point to One-click.
4. Click the corresponding icon.
Save to PC
Scan documents or photographs and save them to a computer.
The Save dialog box opens when you click this button. Specify the scan/save settings and scan.
Save as PDF file
Scan documents, save them as PDF files and start the specified application.
The PDF dialog box opens when you click this button. Specify the scan/save settings and scan.
Attach to E-mail
Scan documents or photographs and attach them to e-mail.
The Mail dialog box opens when you click this button. Specify the save settings and e-mail software program, and scan.
OCR
Scan text documents and open them in OmniPage SE by default.
The OCR dialog box opens when you click this button. Specify the save settings and application, and scan.
May 18, 2010 | Canon MP520 All-In-One InkJet Photo...
I have a cannon 160 printer but when I click on it, the screen to ask about scanning or print doesn't show.
I have a mp470. Try this before the driver download. Click Start, click all programs, select Canon utilities, select mp navigator, click on mp navigator again. On my pc this opens a window where I can select Scan/import from the platen or from a memory card. If this does not work here is a link to Canon to get your drivers. Note: turn off and uninstall your MP160 before installing the new drivers. Select your operating system from the list and select your desired drivers.
I also have a mp470. Try this before the driver download. Click Start, click all programs, select Canon utilities, select mp navigator, click on mp navigator again. On my pc this opens a window where I can select Scan/import from the platen or from a memory card. If this does not work here is a link to Canon to get your drivers. Note: turn off and uninstall your MP470 before installing the new drivers. Select your operating system from the list and select your desired drivers.
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=334&modelid=13368
Feb 16, 2010 | Office Equipment & Supplies
I have Canon Pixma mp470 won't scan to my computer
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=334&modelid=15403
Feb 11, 2010 | Office Equipment & Supplies
Canon pixma mp220
I had the same problem, and this is the fix.
1. Go to Canon's website and find the "Drivers and Downloads" section. From there, you will need to specify the subcategories of your hardware, and then your specific model (for example: Hybrid (i.e.-Printer & Scanner), Inkjet, MP470 Series)
2. When you find the proper page for your model printer, select your operating system from the drop down list.
3. Scroll down the page. You will see all versions of the drivers and programs to download. Download the latest version of the driver. You should also download the "My Printer" program. This is useful for troubleshooting and maintenance.
4. Keep scrolling until you find the "MP Navigator" program. This is a very important program, and is necessary for the scanner to operate properly. Download this program.
5. One MP Navigator is downloaded, verify that the scanner will use this program when it operates. To do this, go to the Start menu, click on Control Panel, click on Scanners and Cameras, click the printer that you will be using, then click properties. Click the tab at the top that says "Events." You will then see a drop down menu with the options Save to PC, Save as PDF, etc. Verify for each option that your computer is either opening the MP Navigator program, or that the computer will prompt you on which program to open.
This should get your scanner working. Hope this helps!
Mar 05, 2009 | Canon PIXMA MX310 All-In-One Printer
My Canon MP510 scanner won't scan - the printer works fine, but I can't get it to scan. It used to work just fine.
Try using your scanner from your computer, I'm using windows XP and when i go to My Computer and the printer is connected i see a section that says Scanner and Cameras, your printer should be there, click on it and follow the easy step to scan a document.
Nov 28, 2008 | Office Equipment & Supplies
Can't scan on my Canon MP600
What you need to do is go to the Canon driver downloads page and download the MP Navigator. I had the same problem becuse the disc that came with the printer doesn't work with Vista. You have to know which programs to download! You only need the MP Driver and the MP Navigator and all should work!
Apr 19, 2008 | Canon PIXMA MP600 all-In-One InkJet...
Canon Pixma MP450 All-In-One InkJet Printer Logo
369 people viewed this question
old marine
old marine
Muntejaya Ginting
Muntejaya Ginting
Ekse
