Question about HP LaserJet P3005dn Printer
What does this mean on my HP LaserJet P3005dn Printer, error 49.c02
Mark Schmit
  • HP Master
  • 1,915 Answers
This error is usually caused by out of date firmware. The printer is getting commands from a program like Acrobat it does not understand. Click thi slink to go to support page for your printer. Drivers Software Firmware for HP LaserJet P3005 Printer series Download the current firmware, I suggest the easy firmware update which is the first option, and then run that file.
Posted on May 23, 2014
1 Related Answer
leroyal
Leroy Elliott
  • 2120 Answers
SOURCE: 49.c02 service error message on HP laserjet 4100
General printer error. Unplug the power cord for 10 seconds.
Posted on Feb 06, 2009
I have problem of hp laserjet p4015printer 57.07error
This appears to be a fan disconnection or malfunction.
It will need to be serviced by an engineer who knows the internals and can open the printer without damage.
1 Verify that the connector J65 on the dc controller is firmly seated. 2 Listen for the fan to operate while the MFP is initializing. 3 If the fan does not operate during the initialization sequence, replace it. See Main fan (FN101) and reversing-unit fan (FN103)
HP RK2-0278-000CN Cooling Fan
MFG Part Number: RK2-0278-000CN Condition:Refurbished MFG:HP This HP RK2-0278-000CN is Genuine and works with the HP 4200, HP 4240, hp 4250, HP 4300, HP 4345, HP 4350, HP M4345, HP M4349 Printer series. Parts are thoroughly tested, inspected for damage & defects and guaranteed 100% fully functional.
Feb 06, 2016 | HP Office Equipment & Supplies
Hp color laserjet cm1017 mfp 49 service error showing in disply screen and restart the printer
Aug 15, 2011 | HP LaserJet CM1017 MFP All-In-One Color...
49 error on HP laserjet 3050
HP Printer Error 49 is normally caused by a communications failure between your PC and the printer. If you have an HP printer you may receive the HP Printer Error 49. This is normally effected by a communications breakdown between the printer and the PC, or related file errors.
Check this for Full solution- HP Printer Error 49
Aug 15, 2011 | HP LaserJet 3050 All-In-One Printer
Printer error :"49.C02 service error " message
i think this caused by your windows is not genuine
Jan 14, 2011 | HP LaserJet 4700 Printer
My hp laserjet 3005 dn displays error 52. problem?
hello
i will help you solve the issue --
your printer is this one, correct ? HP LaserJet P3005dn Printer - model p/n Q7815A
review some information to verify where the issue comes from
manual = http://bizsupport1.austin.hp.com/bc/docs/support/SupportManual/bpl05339/bpl05339.pdf
user guide = http://bizsupport2.austin.hp.com/bc/docs/support/SupportManual/c00774394/c00774394.pdf
Nov 02, 2010 | HP LaserJet P3005 Printer
Jan 21, 2009 | HP LaserJet 4350 Printer
LaserJet 4350n Error 49.C02
49.XXXX PRINTER ERROR To continue turn the printer off then on Description The printing operation has been aborted. The issue can be caused by a firmware error, invalid print commands, corrupt data, invalid operations, poor quality parallel cables, poor connections or specific applications. Action
  1. Press Cancel Job to clear the print job from the printer memory.
  2. Turn the printer off and then on to clear the error message.
  3. Try printing a job from a different software program. If the job prints, go back to the first program and try printing a different file. If the message appears only with a certain software program or print job, contact the software vendor for assistance.
  4. If the above action does not solve the issue, contact HP or authorized service provider.
Dec 05, 2008 | HP LaserJet 4350 Printer
What is MemTest failure replace DIMM0 on an HP Laserjet P3005dn?
It says to replace the DIMM, but you really need to replace the formatter. We run into this all the time with this model of printer.
Feb 13, 2008 | HP LaserJet P3005dn Printer
HP LaserJet P3005dn Printer Logo
117 people viewed this question
Ekse
efs_perpends
efs_perpends
