Televison & Video Logo
Shockin hankin Posted on May 21, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do you get it out of 3d what do I adjust, its not a 3d tv
Steve
Level 3:
  • Master 3,290 Answers
  • Posted on May 21, 2014
Steve
Master
Level 3:
Answers
3290
Questions
Helped
1128043
Points
12184
This is an color projector alignment issue. Many projection TVs have a menu item in the video or picture setup that will produce a grid overlay on a black screen of Red, Green and Blue. You use the <, >, up & down buttons on the remote or the TV to move each color (one at a time) directly on top of each other and maintain straight up and down / left and right lines. Once you do this, the picture will be in focus and there will be no more colored "3D-like" ghosting. If you are unable to move the colors far enough, there may be an issue with certain integrated circuits inside the TV that can be challenging to remove and replace. More make and model number for your TV would be required however.
Does my Sony kdl55w829b 55 inch HD 3D Smart tv have a built in 3D transmitter to use with the active 3D glasses ? If so how do you activate 3D viewing ?
This TV has the active 3D transmitter built in to it in some regions. It is included for the model sold in the U.K.
You need to register the Active 3D glasses before they will work with the TV. To register the glasses, turn on the TV and bring the glasses within .5m of the TV. Then press and hold the power button on the glasses for 2+ seconds (until the power button blinks alternating green and yellow). When the registration is successful, a message will show on the bottom of the TV and the green light will stay on for 3 seconds. This will need to be repeated if you use the Active 3D glasses with another TV and then use them again with this TV.
Now you need to activate the 3D feature on the TV. Press the 3D button on the remote or press the control bar on the Touchpad remote and slide the touch pad to the 3D icon and select it. Then choose your 3D option. You may also need to adjust the 3D display settings from the Home button. Press Home and select Settings. Then choose Display and then 3D.
The manual for the KDL-55W829B is available here: http://www.sony.co.uk/support/en/product/KDL-55W829B . The Help Guide, http://download.sony-europe.com/pub/manuals/tvhc/14HE468112-EN-Print.pdf , has the information on using the 3D feature starting on page 56.
I hope this helps.
2answers
View 3D on wd-y65
Ur tv does nt support 3D. U can still see 3D if connected to PC. With power DVD 11 u can able to watch anaglyph 3D.
Dnt get confused any standard screen (e.g. CRT (big boxes with curved screen)) can view anglyphic 3D content.
2answers
Hello, I have a panasonic tc p55st30 plasma tv and just bought the panasonic ty-ew3d10mk1 glasses pack.... I cant seem to get them to link up to watch 3d. I change the tv to 2d-3d but glasses do not seem...
i would check the user manual if it were me. Here´s the an excerpt from the manual.
* For more detail on usage of 3D Eyewear (Power button and Accessories etc.), please refer to operating manuals for the purchased 3D Eyewear seeing it differs depending on the type of 3D Eyewear (Model No. of 3D Eyewear).
Wearing the 3D Eyewear Turn on the 3D Eyewear Put on the 3D Eyewear
View When the HDMI receives information in which 3D mode is detected, 3D images are automatically displayed according to the signal. If the 3D images are not displayed correctly or the images cause discomfort, the images can be adjusted by "3D format select" or "3D settings". ? Change the view 3D?2D, 3D settings (p.25)
After Use Turn off the 3D Eyewear. After using the 3D Eyewear, store it in the case provided.
40hx800 bravia will not recognize sony 3D transmitter
make sure it is centered and the braces are level
or
Probably the stand is not seated properly into the bottom of the tv.
or
If the image is slanted, an internal adjustment is required.
do vote if it helps ya out
3answers
How to play a 3d movie on a normal HD screen.............
Unfortunately, there is no way you can do this without making some adjustments to either the movie clip or to your TV.
These adjustments could eventually end up in making the 3D movie more or less a normal HD movie.
The best way is to buy a 3D TV and glasses. This would help you watch the movie in 3D.
Picture looks like 3d i have ajusted screen but keeps going back to 3d and picture is bowed
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
•Screen looks 3D
•Colors don't line up
•One or more colors can't be adjusted when using the convergence menu.
•Screen is bowed or warped.
•TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems
fcabb43.pngCONVERGENCE SOLUTION
You can see some more examples and find a fix using this link on Fixya - CLICK HERE
My tv looks like it is in 3D without 3D glasses,
Projection TV2_bing.gif sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony, Samsung2_bing.gif, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith2_bing.gif, and others. You can get a convergenece repair kit from the link below.
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on - TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash2_bing.gif focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a solution
93a1209.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you know what you are doing. If you have never done this before we would advise calling a shop or if you want to do it yourself get a complete kit with instructions and support from www.TvRepairKits.com
My convergence is off I believe the antenna from the Wii game through it off now my t.v. shows a 3d picture. I opened the back and adjusted the red lense but the convergence is still off it doesn't show 3d...
keep adjusting the tv until the tv shop has to charge you twice as much for having to correct all your adjustments and for repairing the convergence board why would you adjust something that is factory set? did you think the lens slipped out place?
3answers
Need to activate dvdxcopy gold
this software in my own experience is not very user friendly. I recommend getting on a torrent site and trying different DVD software instead actually. Unless you purchased a key, then click on help, and there you should be able to enter your key code to activate in the 'About' section or Register.
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
