Toshiba e studio 212 . After replacing lithium battery (3V) from circuit board of machine the display panel started blinking, it does not stop and doesnot show anything. Please help
SOURCE: I have Toshiba e studio 207 copier machine. After
If not the contrast switch problem, u can try reset the machine by pressing "*13" and ON the machine.
SOURCE: Dear sir, when i start my Toshiba e.Studio 166
yes sir it is signal your copier exproser lamp or lamp fuse is cut please chack it then solve your problem
SOURCE: Toshiba E-studio 600 display F130 error
The NVRAM on the SYS board stored information of MFP such as counters,
serial number, settings and etc.
If u swapped SYS board, then the serial number of MFP will be different.
U need to assign the correct Serial number at 08-995.
Or, use back your original NVRAM on your new SYS board.
Testimonial: "Thank you so much! "
