Store memory
SOURCE: Need owner's manual for IBM/Lexmark wheelwriter 30 series II
I can send you acopy of a ww30 manual for 25.00
DickyO
SOURCE: IBM Wheelwriter 10 Series II 6 Beeps 1,2,3 Blinking
Check in the area where the printwheel is installed for paper or other debris. If it does the same thing with the printwheel out then it is probably a printwheel sensor.
DickyO
SOURCE: IBM Wheelwriter 30, Series II has message KYBD 099
Tour keyboard is going bad. Hold the code down press lang (L) key release the "L" type 001, release the code key this should put you on U.S. keyboard mode. For a better repair you can try my tip under WW1000 or contact Geo Beyers Co. @ 800-392-8085 for a keyboard rebuild. Tell them O'Reilly sent you.
DickyO
SOURCE: IBM Wheelwriter 30 Series II Since changing
The ribbon may not be fully seated on the ribbon deck. The blue latch has to hol it in place.
DickyO
