Question about Yahoo
Can I change my mobile number? - Yahoo
Posted by dan caldwell on
D & B Enterprises
  • 778 Answers
Hello, Yes you can change your phone number. You will have too call your cust. support for you cellphone provider in order to do this.
Posted on May 21, 2014
How do I change my boost mobile number?
    1. To do this, you will need to type in your Boost mobile phone numberinto the box that asks for your mobile phone number on the Boostwebsite, which is found at 'http://boostmobile.com'. Next, you must type in your password. If you have forgotten your password, you can have a new password sent to your e-mail address.
      How to change your Boost mobile number - Quora
      https://www.quora.com/How-do-you-change-your-Boost-mobile-nu... Quora
    Feedback
  1. Boost Mobile - My Account
Dec 26, 2015 | Cell Phones
How do I change my mobile number on my gmail address
To know how to change your mobile number on Gmail account, you can refer to the link below:
http://www.fixya.com/support/t25759231-change_mobile_number_email_address
GuruAid.com
Jun 24, 2015 | Computers & Internet
Facebook need to change my phone number for Facebook
Change your phone number in your Facebook account Settings, General Settings.
Dec 08, 2014 | Facebook Social Network
Atmt CODE ?
  • Menu->Settings->Security->Anti-Theft mobile tracker.
  • Here two options Set ATMT and Number for ATMT are found.
  • Make Set ATMT code to be 'ON'.
  • In Number for ATMT code type 0000(i.e default ATMT code ,user may change this code in change codes options).After typing 0000 (ATMT CODE) it will ask for Name and Mobile number provide it in order to monitor the anti-mobile theft tracking operation for the specified name and mobile number.We can change the settings at all time.
  • For change ATMT code it will ask for old code if the mobile is newly buyed and not any ATMT codes are manually assigned then you can type 0000 which is the default ATMT code for Anti-Theft mobile tracker.
Oct 17, 2013 | LG Cell Phones
How to change my number in im mobile
Click on "Messenger" in the top left hand corner of the Messenger Toolbar.
Click on "Preferences".
Click on "General".
Click on "Edit Mobile Phone" at the bottom.
In the "Other Mobile Devices" section, click the trash can Icon which is under "Delete". (There should only be one entry to delete.) The "Delete this Device" window opens.
Select "Remove alerts for this device" from the "Delete this Device" window.
Click "Delete Device" to confirm.
When this is done, add your new Mobile as follows:
Click on the little mobile phone icon under the Custom Status message box.
Click on "Set up Mobile Phone".
A new window will open up to enter the details of your new mobile phone. Enter the telephone number of your mobile device in the "Number" box and click on "Continue". You will receive a text message with a confirmation code on your mobile device. The "Get Yahoo! Messenger on Your Mobile Phone window" changes and it asks you for the confirmation code you just received on your mobile device.
Enter the 4-digit confirmation code in the "Enter code" box and click to select the check box option for "Automatically sign me into my mobile phone when I log out of Yahoo! Messenger on my PC". Click "Next". (The Get Yahoo! Messenger on Your Mobile Phone window changes to tell you that you've successfully registered your mobile device.) Click on "Done".
Apr 18, 2011 | Yahoo Messenger
I must change my imei number.
Hello
The international mobile equipment identity number or IMEI number is a unique number for phones in order to identify that particular mobile phone. Every time a phone is used an electronic fingerprint is transmitted to identify the handset. These numbers are used to reveal the identity of phones so that they could be marked as grey marketed and blocked if necessary. As much as it is possible to change an IMEI number, it is not easy to do so. To change the number you need technical skills and sophisticated equipment.
Even if you end up doing it, you must know that changing a mobile phone's IMEI number is considered a criminal offence according to the criminal code. Even if you are holding any data or device with the intention of changing an IMEI number, you could be taken for trial.
Hope this helps
Jan 18, 2011 | Samsung B5722 Cell Phone
How do i change my mobile number in yahoo messenger?
Go to messanger in the task bar menu and choose My Contact Details. Then you should be able to change ur mobile number under primary which has 3 different phone number settings which are home work and mobile.
Jan 18, 2011 | Computers & Internet
How to change my mobile number in yahoo messenger.... because i cant change it.... thank u in advance....;
Hi, Changing mobile Number In yahoo messenger.
1.First To yours yahoo messenger, from there in messenger menu bar(found at the top of the window), click Messenger, then Preferences. You can also use Ctrl+Shift+P for shortcut.A new Tab Will Open there In the General Category, you will find the button “Edit Mobile Device.” (at bottom) Just click it then a new window should appear in your screen for editing.And you are done. 2.As you Click “Edit Mobile Device” It will redirect you to Yahoo mobile service , after reaching in that page click ” Delete ” buttom ( garbage box ) to delete yours messenger service or Click “Edit” To change Mobile number.
Regards, polysandy
May 20, 2010 | Yahoo Messenger
Hi! how i can change my sonyericcson w595 imei code?
Did you say you want to CHANGE your imei code, that is certainly IMPOSSIBLE...
But if you want to CHECK you imei code, you can dial *#06# on you mobile phone and you will get the 15 digits number.
GOODLUCK
Jan 07, 2010 | Cell Phones
I lost my samsung s3310 on 20 august,2009 how to get it back
is your mobile tracker kept on??
if it is ON... the person who took your mobile and when he/she changes sim card ,the mobile tracker sends message to the two recipients (whom you have specified when activating mobile tracker)with IMEI number and the changed sim card number..
you can call to the changed sim card number to return ur mobile OR u can file a complaint with ur IMEI number...
if it is OFF..oops pray to god
Aug 27, 2009 | Samsung J700 Cellular Phone
Yahoo Logo
259 people viewed this question
Top Yahoo Apps Experts
Gustavo Ortiz
Gustavo Ortiz
Marvin
Marvin
Harrie
Are you a Yahoo App Expert? Answer questions, earn points and help others
