Question about Xerox CopyCentre C20 Black and White Copier
Why is my canon imagerunner 1023 makes a squeaking noise when printing?
1 Related Answer
Rick Kasper
  • 2072 Answers
SOURCE: Xerox Phaser 4510 - While printing it makes a squeaking noise
One of two things. The fuser bearings get noisy in those.
Or there are several small hard plastic rollers on steel shafts or even mounted on springs they they can get very noisy.
Posted on Feb 24, 2010
Download for Canon ImageRunner 1023 printer
You can download the Drivers for this printer at
http://www.usa.canon.com/cusa/support/office/b_w_imagerunner_copiers/imagerunner_1023_1023n_1023if/imagerunner_1023#DriversAndSoftware
Select the driver for the Operating System you are using.
Mar 07, 2011 | Canon imageRUNNER 1023iF Black and White...
I buy this model plz tel me the funcatiion of this model ir 1023
Canon imageRUNNER 1023 Basic Operation Guide
IR 1023 is capable of copying, printing, scanning and faxing.
Please visit the above link and download/ save the Basic Operation Guide for ready reference in future.
Hope it helps! Good Luck!
CreativeTECH
Feb 18, 2011 | Canon imageRUNNER 1023 Black and White...
Canon ImageRunner 1023 copier keeps making a clicking noise after I hooked it up to the phone jack to fax
first did You connect the tel. line in the jack where is marking L ? if not connect it.
Try to connect the plain telephone on that line and try to dial somebody to see if the line is OK.
... In most cases when the machine starts to produce the click sound it means that the fax board is defective and you need to change her.
Regards.
Jan 07, 2011 | Canon imageRUNNER 1023iF Black and White...
Everytime I try to print an envelope using my Canon imageRUNNER 1023iF I get an error message. I'm using a Microsoft Works Word Processing program. I have loaded the envelope tray and nothing happens...
To get rid of error, unplug machine.
Sett. the correct paper size ( size of envelope ), paper type (envelope ), both on printer properties ( when you prompted to print ) and on machine ( when you put envelope on bypass, machine auto ask you ).
Do not forget to tell printer that he needs to take paper from bypass ( printer properties )
Hope that helped
Jul 04, 2010 | Canon imageRUNNER 1023 Black and White...
Describe your canon imagerunner 1023 how to
1) on copier you have a button add. functions-something like *
2) with + or - trough the menu press OK at FAX sett. or under report sett.- If I recall its under Fax sett.
3) try to find report sett. then OK
4) you must enable the RX REPORT than OK
For transmision report you must enable TX REPORT
Jan 13, 2010 | Canon imageRUNNER 1023iF Black and White...
Blank scans- canon imageRunner 1023N
Blank image = transfer/separator unit/corona is not working. Please check the transfer unit.
Aug 19, 2009 | Canon imageRUNNER 1023 Black and White...
ImageRunner 1023N.. assign IP
Press the additional funktion buton,press the arrow keys until 9 system settings is displayed press ok press the arrow again until 5 neywork settings is displayed press ok.TCP/IP settings will be displayed press ok and change the ip to your network adminatrators specifications.
Aug 17, 2009 | Canon imageRUNNER 1023 Black and White...
IR 1023 iF goed on - doen not print
re-installed the driver after deleting as administrator - power user does not seem to allow certian vista installations.deletions - geez
Jan 26, 2009 | Canon imageRUNNER 1023iF Black and White...
Cannot print to cannon imagerunner 1023. got an a message on the print log NG(#0853)
I found a solution for this problem on an Canon IR 1022 in a russian forum (thanks Google language tools)
The solution was, not to use the PCL5 driver, but to download and install the UFR / UFRII drivers from the Canon support site. With this drivers, everything works fine.
Olli
Jul 25, 2008 | Office Equipment & Supplies
Xerox CopyCentre C20 Black and White Copier Logo
61 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Tareq Bin Mostaq...
Tareq Bin Mostaq...
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
