Question about Maax Water Heaters
What is a requarement for motor, do we need it to be bonding ?
Posted by Edward on
Gene Haynes
  • Maax Master
  • 5,391 Answers
Motor must be grounded with ground wire.
Some local codes require outdoor motor shell to be bonded, with a ground rod driven into ground and ground wire attached... in addition to ground wire back to panel.
Never hurts to bond outdoor electrical devices.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Posted on May 24, 2014
Rusty smelly hot water
The rust can be from rusted pipes, and not necessarily tank:
New tank has new anode rod, and is NOT likely to be cause of problem.
Anode only protects the tank... not your steel pipes.
There are mathematical formulas for figuring what size and type anode is needed for steel structures like bridges and water heater and boat hulls... if anode is too small or deteriorated, or coated in calcium, or not electrically bonded to the steel surface, or if tank is not full of water or boat hull is out of water, then anode cannot protect the steel.
For more insight about problem:
http://www.thetankatwaterheaterrescue.com/forums/forum3/
http://waterheatertimer.org/Replace-anode-rod.html
Gene h
Mar 20, 2014 | Premier Water Heaters
BOSH EXXCEL 1200 EXCEL IS HAVING LOUD CRACKLING NOISE WHEN SARTING. THIS IS BEFORE THE DRUM STARTS TO TURN.
It the motor there are carbon brushes in there when they wear down they don't touch commutator... on motor what u here is arcking u shud b able to re place them u will need a model number and make, ..or remove motor and take with u to get right brushes if the moyor is badly burnt u will need to replace it if u continu to use like this it will only get worse
Oct 12, 2013 | Bosch Water Heaters
Water heater pipes
1) Electrically bond pipes to ground to avoid stray current corrosion.
Use pex-lined di-electric nipples instead of dielectric unions.
Unions depend on rubber washer and will eventually leak and corrode.
http://waterheatertimer.org/9-ways-to-save-with-water-heater.html#straycurrent
http://waterheatertimer.org/9-ways-to-save-with-water-heater.html#di-electric
Mar 15, 2013 | Water Heaters
While installing the heater I dropped the unit on its top and and smashed the sheetmetal caseing. How can I rest assured that the tank inside did not break? Is there a glass liner inside?
They construct a steel tank, then bond vitreous glass to the inside of it to keep it from rusting. There are variations in manufacturing quality, however, so some tanks might have a better glass lining than others. And there is always a small amount of steel exposed, due to limitations in the coating process.
The tank is protected with a insulated coating on the liner to protect it for damage even if the shell get's bent up. You can put water on it to test it for any leaks. I don't recomend putting a air test it could be dangerous to do so. If it fell from a upright position and not off something higher then it should still be ok.
Aug 04, 2011 | RTO Bock Water Heaters 361E 91 gal 415,000...
Hi, our recently installed everhot 20 continuous flow is anything but continuous, well, not hot anyway. Sometimes it works fine, other times all we get is cold water that feels like it is starting to get...
If you installed yourself call the support number from the owners manual. If you had a professional do it call them and tell them to fix the issue. This is not normal. If they don' t contact your states contractors license board and get their bondong company info and call the bonding company. When they get that call they will fix it. There are way to many variables to try and TS this issue.
May 13, 2011 | Rheem Water Heaters
Stop 2min and run for 2min, stop 2min and run for
your motor thermal safety relay is protecting the motor from burning out
this is usually caused by: an old motor about to fail (tight shaft bearings) bad centrifical switch or, an obstruction in the water flow causing the motor to work too hard (draw too many amps, get too hot then cool down and, start up again
check the relay it is located on the side of the motor on most motors; under a cover; unless the motor is bad the relay may just be too sensitive (old) and, may need to be replaced.
Jul 24, 2010 | Whirlpool Jacuzzi Jacuzzi Bath Fuzion EF50...
Grounding wire# 8 cooper
The # 8 wire is a bonding wire for the hot tub or jacuzzi. It is to interconnect all the metal parts and equipment associated with the unit, pump, pipes, handrails, and also now there is a bushing that goes in the piping run to bond the water itself .
This wire will be incdentally connected to the electrical ground when it is bonded to the motor body.
Jun 10, 2010 | Jacuzzi RapidHeat Inline Heater S750
Cracked water heater
Clean the crack up and expose clean metal by sanding it or a small grinder. Use JB weld it is a two part mixture that set's up hard as steel. Any hardware store should carry it.
I have fixed gas tanks,glasses and a few other thing's with it.
The main thing the surface has to be clean so the compound get's a grip to the metal. Since you already have a crack the compound will go into crack to get a inside bond.
You may use a small file or sand paper to open up the crack a little by adding a bevel to groove to expose shinning metal to get acurate bond.
Drain tank and let it dry out before attemping to fix.
They make all kind's of JB weld for different types of applications and Lowes or Home Depot will carry it.
Check out this link http://jbweld.net/index.php
Jun 09, 2010 | RTO Atwood DSI-RV Water Heater-6 Gallon
On BL6505 blower motor do I need separate White wire to capacitor other than white wire on motor
the white wire is the common. your red or black will hook up to the capacitor on the line voltage side of the circuit. should come into the the cap from a switch and out from cap to the motor
Dec 30, 2009 | Water Heaters
Kohler sok overflowing tub motor will not run theres power and green light indicates it should work
maybe the motor is not working any more, if you have curent to the motor but not thru the motor you need to get a motor
Apr 03, 2009 | Kohler K-1188-C1-0 sok overflowing bath...
Water Heaters Logo
Top Maax Water Heaters Experts
Paul Carew
Marvin
Marvin
Are you a Maax Water Heater Expert? Answer questions, earn points and help others
